Question about Cobra 29 LTD CB Radio
Cobra 29 ltd night watch with sound tracker i want to convert it
I want to convert it so i can go on other channles all i know is that you can convert them so it will do high mid low etc bands some if you can please tell me thankyou :)
Go to a CB shop and have them put in an "A" board. Then have them tweak & peak. Got mine done for $80.00.
Posted on Jun 11, 2007
I have a cobra 29 nighthawk with sound tracker i
Check antenna conditions.
Bad Impedance antenna,must have 50 Ohms
Sep 04, 2013 | Cobra Radio Communications
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
Is it possible to convert the cobra 29 wx nw st sound tracker cb to 10 meter amateur band?
No it cannot. If you want that buy a Ranger or a Galaxy.
The 29 can be altered to increase modulation and turned down in power to match it to amp for increased output of power.
Set to dead key a watt or so with a 100 watt amp it would dead key low and swing to 80 to 100 watts pep.(peak envelope power)
Mar 16, 2012 | Cobra Radio Communications
I have a bare wire (shield),white,red,and blue from mic. What is the correct pin configuration for a cobra 29 night watch
  • Pin 1 = Shield = Shield
  • Pin 2 = White = Audio
  • Pin 3 = Red = Transmit
  • Pin 4 = Blue = Receive
Regards, Tony
May 05, 2011 | Cobra 29 LTD CB Radio
My 29ltd NW Classic will power up but will not transmit or receive. Occasionally it will, but then suddenly go dead. Sometimes I can tap on the bottom of the cb and it will kick back in momentarily, only...
hi I had the same problem on my cobra uk 29 ltd st night watch it turned out to be dry solder joints if you remove the top cover and look to the right of the board you should see a oblong silver protector cover i found if i taped it lightly it worked then it didnt so i removed it the dry joints were under there hope this helps.
Jan 29, 2011 | Cobra 29 LTD CB Radio
No problem just need wire diagram for 4 pron mike on cobra 29 night watch sound tracker
go to cobra web site click on contact us tell them what you need and thay mite be able to send it to you
Jan 03, 2011 | Cobra 18 WX ST 40-Channels Base CB Radio
How do turn a stock one up? cobra 29ltd and a night watch 25
We all know one is not "supposed" to up the power on a standard CB to more than 4 puny watts...lol. Get your favorite local technician to do a good combination of power/modulation final tuning. Excellent modulation is what really makes the difference, along with a strong power mike. Cobras are known for good quality modulation! Thanks, Bill
Aug 01, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Cobra 29 ltd sound tracker cb
you start by replacing every electr cap as most cb radios live in a hostile enviorment, They ALL suffer from dried up electolite. if the set is old ,that will be you first step,if you are up to speed with desoldering with out lifting copper tracks/etc, no reason why you can't have a go...do not shift trim pots or tuning can slugs
with out marking their factory positions as this can end up in a
mess
CHEERS
Jun 26, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
128 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
