Question about Garmin zumo 550 GPS Receiver
Garmin zumo 550 map update problem
Tried to update to CNE NT 2009 using the DVD. PC updated fine, GPS unit failed to update, and left me with base map only. Tried several more times. It repeatedly failed at the same point (27%) when transferring the maps to the unit. I cleaned out unnecessary files (voices, routes etc.) to free up space and then master reset the unit. Same result: failed at 27%. I tried transferring the new map via Mapsource: same result. Then I tried transferring the old map via Mapsource: it worked, and the old map (V9) worked fine.
But I want updated maps, so I ran the update from the DVD again... and it failed to udate.
Does this point to a problem with the new update? Has anyone any ideas? I need help!
  1. Make a backup of your Zumo by copying all the file to your computer.
  2. Using your PC and MapSource select all the maps then send them to a SD memory card need 2Gig or bigger card.
  3. Try to rename this file to gmapprom.img and replace the same named file in your zumo. (I haven't tried this personally, so if it fails, just replace this with your backup and all will be as it was.)
  4. If this fails, you can use the SD memory card in your zumo and it will use this map instead, but it will take longer to boot your zumo.
Posted on Apr 11, 2009
  • myro99 Sep 24, 2010
    Garmin support answer:
    Question: How do I get more space on my nuvi, StreetPilot, or zumo for the map update?
    Answer:
    To free up more space on your nuvi 200, 205, 300, 465, 500, 5000, 600,700, 705, 800, 805 series, StreetPilot C500 series, and zumo 220, 450, 550, 660, 665 series you must remove unnecessary files, please follow the steps below:
    1. Connect the nuvi, StreetPilot, or zumo the computer with a USB cable.
    2. Find your My Computer icon and double click on it or you may find it in you Start menu and click on it.*
    3. Double click on the Garmin drive listed under devices with removable storage
    4. Double click on the Garmin folder
    5. Double click on the Voice folder
    6. Delete any unused voice language (be sure to keep your preferred language).
    7. Return to the Garmin folder
    8. Repeat steps 5-7 with Text and Help folders
    After the files are deleted please empty the recycle bin or trash. Once completed please run the map update again.
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
Just purchased zumo 450. map is not up to date. have loaded city nav nt to computer but not upto date either.
Hey, you can use the webupdated to update your gps
http://www8.garmin.com/products/webupdater/
Lets see about the map update it may need to be purchased. try the webupdated now first.
Sep 14, 2008 | Garmin GPS
When I turn my Garmin 550 on it says loading maps, then goes to the select a local: It's frozen their on United States i push OK and nothing happens can not change the Locale it's frozen I tried...
Hi tkfranks331,
Press the power key and hold it if the screen of your Zumo is frozen. Keep holding the power key while pressing the key that has a plus symbol ("+") on it. This will reset your device and unfreeze the screen. You can also try calibrating the screen by pressing the power key for one full minute.
If this does not work, please follow these steps.
1. Update the internal disk software. Download and install WebUpdater on the computer. Please visit this link to download the WebUpdater.
2. Open WebUpdater on the computer.
3. Connect the Zumo 550 to the computer with its USB cable.
4. WebUpdater will automatically search for updates.
5. Follow the prompts to download any pertinent updates for the Zumo 550.
Hope it helps.
Thank you for using FixYa.
Aug 17, 2011 | Garmin zumo 550 GPS Receiver
My Garmin Nuvi 550 has quit talking to me. I understand the unit must be connected to a power source in order for it to speak. I have not paired it to my cell phone or downloaded the MP3 files. I have...
You should download, install then connect and run the Garmin WebUpdater on your nuvi 550 first. The new maps shouldn't have caused a problem - but stranger things have happened. After the firmware update, you will have the latest firmware to go along with those maps you installed.
IF you're still having problems, the Service Reps at Garmin are about as knowledgeable as they get for Garmin products. Give them a call on their dime too - there are other ways too - pick which method suits you best from the choices here.
Please rate this reply if it was helpful - good luck!
Aug 12, 2010 | Garmin zumo 550 GPS Receiver
Need to up date maps
Create an account at myGarmin regsiter your unit ID number this will allow you to unlock the maps that you buy. You then have two options the first requires you to have an NT 2009 or 2008 map already installed.
nüMaps Lifetime™This will cost you £99.99 and is a on off payment Remember — this map update can only be used to update the preloaded maps that came installed on your Garmin GPS device. For example, a Garmin GPS device preloaded with North America maps only cannot be updated with a nüMaps Lifetime Europe Map Update, and vice versa. Check product compatibility. nüMaps Onetime™ This will cost you £79.99 and does not rely on having a map already installed.
The City Navigator® Europe NT comes on a DVD or you can download it.
LOL
Oct 03, 2009 | Garmin nuvi 200W GPS Receiver
No loadind of maps after updating
I have a Nextar gps worked fine for awhile now when i turn it on all it says is reloading. i tried to shut it oee an start again and the same thing happens.
May 22, 2009 | Garmin GPS
Need help unlocking maps in City Navigator NT North America.
I turns out that the unlock code was discreatly printed at the bottom of a yellow piece of paper in the packing.
Mar 21, 2009 | Garmin zumo 550 GPS Receiver
Lines Running North and South
How do you load maps? and are these Garmin maps. I try to keep the Zumo original and use an SD card for extra maps. Did you try this yet? And if you are using SD cards, try a different brand/quality. I had some lockups with crappy budget cards. Kingston, Sandisk and some other A brands work fine!
Oct 16, 2007 | Garmin zumo 550 GPS Receiver
Zumo 550
Go to the garmin website download webupdater, use this to figure out what files it needs, and select the apropriate sound files, web updater will download and install them for you!
Aug 13, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
3,085 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
