Eclipse SW8102DVC Car Subwoofer Logo
Posted on Jan 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the following specs on an Eclipse SW8102 DVC subwoofer.
Qes:
Qms:
VAS:
Fs: X-max:
BL:
Le:
Pe(RMS power):
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Jan 10, 2009
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5036853
Points
35540
Http://www.cartoys.com/cartoy/pdfs/Eclipse_spkr_manual.pdf
Page 7 - Enjoy!
Fs: 26Hz
Qts: 0.47
DCR: 4.0 ohm/coil
Vas: 2.01 cuft
Xmax: (one way) 1.20"
For the rest of the T/S, you will need to talk directly to their support line tech :
email: [email protected]
Phone: 310-327-2151
Hope this helps you with your enclosure.
1helpful
What is the vas,fs,pe,qes and qts for a 8000 watts targa venom sub woofer?
5000w Peak PowerSPL (Efficiency, 1W/1M) - 89.1dBNominal Impedance - 2/4/8 OhmsQts (total speaker "Q") - 0.42Vas (Equivalent compliance) - 75.9LMounting Depth: 156mmMounting Hole Diameter: 280mm
I have no idea what to do with my panzer maxp124d subwoofer. There's like 8 terminals on each sub and idk how to wire them
Here are the specs for your speaker.
  • Dual 4 Ohms Nom. Impedance
  • Fs: 40Hz, Qms:5.0, Qes: 0.90, Qts: 0.75, SPL: 84(dB), Vas: 5.204(Cuft)
  • That should help you design a good box.
  • The eight terminals are actually 4 with double slide ons for each. Each side has a + (positive)
    and a - (negative) with 2 connectors at each connection point.
    It is a dual voice coil thus 2 sets of inputs.
    If you have a 4 ohm amplifier then you are ready to go with a left to one side's terminal and a right amp output going to the other. If you have 2 speakers this can get wild because you can run them in parallel
    or series and reduce the impedance to 2 ohms if your amp is 2 ohm stable. If not-dont do it!
    You will burn the amp up. See #58 on the right sidebar of this site. It will teach you how to get the most
    from your setup. Bookmark the site. It has every kind of knowledge you need for audio or electricity.
    Look for the DVC (dual voice coil) info.
    "The image below shows the DVC speaker wired to both channels of a stereo amplifier. Each channel of the amplifier drives a 4 ohm load. " This looks like what you have to do.
    http://www.bcae1.com/
    1helpful
    I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
    The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • 1helpful
    What r the parametric specs for the ma audio hk15x2
    Fo (Hz) : 29.581 QMS : 3.965 QES : .517 QTS : .457
    VAS (liters) : 147.723 REVC (Parallel-Ohms) 1 SPL @ 1 watt/ 1 meter (dB) : 90.6 X-Max Linear peak-peak (mm) 70 LEVC @ 1kHz (mH) : 1.043 Enclosure Volume (Sealed) : minimum 2 cubic feet Fill Required % : 0 3dB down point (-3dB) : 43 maximum sealed: 2.5 cubic feet n fill required: 39 at 3 dB down point Enclosure Volume Ported Vented (cubic feet) : 5.0 Vented to Hz: 35 3dB down point (-3dB Hz) : 28 Square port area Sq/In : 80 Port Length : 13" Power Handling : 2000 Watt RMS & 4000 Watt Max. Make sure to use MDF for the enclosure and use 1 inch thickness and use braces as well. This is a beast of a sub woofer. So give it the proper power it needs and make sure that your box is very solid in construction. If installed correctly and given the right power, this sub woofer is bound to put a smile on your face and rattle your bones. I hit 142dB with only one of these subs and im sure if i gave it more power i could hit the 150dB range. DON'T FORGET TO GIVE IT THE POWER IT DESERVES. Have fun dreamsystems.
    2helpful
    What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
    TS-W307D2
    Design and Specifications
    12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
    Spacks on 15" orion 2 xtreme sub
    Here are the Specs from Orion's spec sheet.
    Sensitivity @ 2.84V/1m 93DB
    FS 23Hz
    QMS 9.05
    QES 0.47
    Qts 0.44
    BL (Force Factor) 8.7 TM
    SD (Piston Area) 500 sq.CM \ 78 sq. in.
    VAS (Volume Acoustic suspension) 224 Liters \ 7.92cu.ft
    Xmax 7.75MM \ 0.30 in.
    Enclosure Recommendations
    Sealed Volume 1.60 cu. ft.
    Vented Volume 2.75 cu. ft.
    Port Dia (Inside Dia.) 4 in.
    Port Length 8.5 in.
    What is the rms for a single max12d lanzar is it 500rms or 250rms
    Description One of the oldest and most respected names in automotive sound is also one of the most consistent winners on the competition circuit. Lanzar offers a wide range of high performance subwoofers, from the pounding OptiDrive Series to the rugged MAX Series. The MAX12 dual-coil subwoofer offers high power handling, great bass response, an economical price, and a 3 year warranty. Specifications: *Power handling: 500 watts RMS/1000 watts peak *VCdia: 2" *Impedance: 4 ohms per coil *Magnet weight: 130 oz. *Fs: 33.6 *SPL: 88 dB 1W/1m *Vas: 3.19 cu. ft. *Qts: 0.47 *Xmax: 10mm *Dimensions: A: 12.09" B: 11.15" C: 6.42"
    I need to know about my 12" dvc eclipse subwoofer but i dont know what modle it is
    Hello brandin_1,
    I'm assuming that you have the new 12" eclipse. Look at the sub cone. If it is blue in color, you have the Model SW4210 12" DVC SUBWOOFER, 4ohm, 250W RMS,750W MAX. If the cone is silver, it is the Model SW6210 12" DVC SUBWOOFER, 4ohm, 500W RMS, 1500W MAX.
    If it is an older dvc Fujitsu Ten 12" eclipse, most likely it is the Model SW9122. If it is a REALLY old 12" eclipse, it is probably a model 88120.
    Hope this helps.
    1helpful
    Need to pick perfect amp
    I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
    Here are my Top 5
    • Lanzar -OPTI4000D
    • MA Audio- HK-4000D
    • JL Audio 1000/1V2
    • OPti 22.2 Power Amp
    • AudioBahn-A5100T
    Top Eclipse Car Audio & Video Experts
    ZJ Limited
    ZJ Limited
    xxxxxx xxx
    Steve Sweetleaf
    Steve Sweetleaf
    Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
