Question about HP Ruggedized DC Car Adapter for HP Deskjet 460 InkJet Printer
I cannot get my HP deskjet 932C installed again. I disconnected it to have my computer repaired. I did unstall and re-install the software, but am still getting the same message that it cannot find LPT1. And foolish me, I threw away the great poster that came with my HP! Thanks
    President:
  • 1,901 Answers
To begin with, here is a link for the user guide for your printer:
HP 930C User guide (Even though it says 930, your 932 should be nearly identical.)
Page 40 begins the setup instructions. If you are going to use the parallel printer cable, the printer port must be enabled in your BIOS. What did you have "repaired"?
It would be easier to get a USB cable and connect it with it, that is if you have a USB connection.
What operating system are you using? That may help me understand your problem better.
Posted on Jan 10, 2009
Stopped printing and will not continue.... the middle orange light stays on
Press the "Power" button to turn off the printer. Wait a few seconds and then power it back on.
Power off the printer again if you are still running into problems and disconnect the power cable from the AC power. Wait a few seconds and reconnect the power cable. Power on the printer. This simple procedure resets the printer back to the default factory settings. Move to the next step if the reset does not work. Select "Setup" on the CD and select "Remove HP Desk Jet 932c. The printer software and drivers are removed from your computer. Reconnect the USB Cable to the printer. The installation disc automatically recognizes it and begins reinstalling the software and drivers.
Here is the link if you cannot find your installation disk:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=25305&taskId=135
Print a test sheet to verify that the printer is now working. You can print a test sheet using a word processing application.
Mar 03, 2011 | HP DeskJet 932c InkJet Printer
I bought another deskjet 932c from e-bay to replace my old one. I have windows 98se which is not connected to the internet. When plugging in the 932c I just bought, a message comes stating that there is...
Try a self test disconnected from the computer by pressing the 2 left buttons for 4 seconds and then wait for about 15 seconds for a test page to begin. Some models were the right 2 buttons pressed for 4 seconds. If it self test ok then it is software or cable interface. Make sure you are using the same USB or parallel port as before or reset the printer properties to that port. Sometimes the printer dip switches have been messed with and your system will not see the printer properly.
Nov 02, 2010 | HP DeskJet 932c InkJet Printer
I am unable to install HP DeskJet 932c printer with Windows 7. I have no install disc. Any way to workaround?
Go to the HP web site (HERE) and select the version of Windows 7 that you need. Download the driver. You can also get documentation there too,
Sep 13, 2010 | HP DeskJet 932c InkJet Printer
Does The 932C have an installation CD, I need to reinstall on a new computer?
You can download the basic driver or the on with all the bells and whistles that came on that CD The Hp website
Click on the link I have given you and put in what operating system you are using, then hit next.
from there click on the + next to drivers to choose from the basic version or full feature version.
I hopes this helps
May 30, 2010 | HP DeskJet 932c InkJet Printer
The ink icon light is blinking
  1. Reset your printer if you are having communication problems with the computer. To do so, press the "Power" button to turn off the printer. Wait a few seconds and then power it back on.
  2. Power off the printer again if you are still running into problems and disconnect the power cable from the AC power. Wait a few seconds and reconnect the power cable. Power on the printer. This simple procedure resets the printer back to the default factory settings. Move to the next step if the reset does not work.
  3. Disconnect the USB cable from the printer. Insert the printer software installation CD into the CD-ROM drive on your computer and wait for it to automatically launch. Click the Windows "Start" button if it does not launch and click "My Computer. Right-click the CD-ROM drive with the disk and click "Autoplay to run the CD.
  4. Select "Setup" on the CD and select "Remove HP DeskJet 932c. The printer software and drivers are removed from your computer.
  5. Reconnect the USB cable to the printer. The installation disc automatically recognizes it and begins reinstalling the software and drivers.
  6. Print a test sheet to verify that the printer is now working. You can print a test sheet using a word processing application (e.g. Microsoft Word) or using the Internet.
May 13, 2010 | HP DeskJet 932c InkJet Printer
How to i run a cleaning cycle on a printer, i
On the CD-ROM that came with the printer is the "HP Printer Support Tools" software. Install it, and run it, and click to run the 'head-cleaning' utility.
Apr 10, 2010 | HP DeskJet 932c InkJet Printer
I have a hp printer 932 model year of 2000 ,i dont know how dose it work with windows 7
Windows 7 may install a driver for your model, but it is likely to have only basic features. You may need to update your Win7 installation by using "Windows Update" before hooking up your DeskJet 932c cable.
Jan 13, 2010 | HP DeskJet 932c InkJet Printer
I lost the CD installer of my HP Deskjet 932c, how I can install it? my problem is that i want to install my printer in my computer
click here
click on above link then select your operating system and download drivers .Then install in your computer then connect your printer to computer with usb cable then it works.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 31, 2009 | HP DeskJet F380 All-In-One Printer
Hp deskjet 932c does not print cartridge light keeps on blinking
First suggestion is to install a new cartridge. The #45 black and #78 color have a small circuit board that registers with the printer. That circuit board may not be doing its job.
Mar 22, 2009 | HP DeskJet 932c InkJet Printer
Color Printing
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 13, 2008 | HP DeskJet 932c InkJet Printer
HP Ruggedized DC Car Adapter for HP Deskjet 460 InkJet Printer Logo
Ben Johnson
