Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Just a Black screen
I have a LG42pc1da plasma tv the power light comes on and flickers if you try to change channel or try to ajust the volume but there is not picture or sound
  • 133 Answers
Needs a Y-Sustain board, about a 300 dollar part, unless you have a warinty, also try turning the tv on, after you get a green light, unplug the tv, after 15 seconds plug it back in, sometimes will make tv come back on
Posted on Jan 10, 2009
My Panasonic plasma tv is stuck on one channel. The remote has new batteries but only works for the volume. I tried changing channels on the set itself and now the screen is black
If the screen is still on but is black, try changing the channel on the set itself back to the channel it was originally on. If you can provide me with the model name of the TV (usually somewhere on the back of the TV), I might be able to find out how to re-set up your remote with it.
Dec 13, 2016 | Panasonic Televison & Video
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
I was wondering if someone could help me find which board could be bad on a Samsung PN59D8000FFXZA plasma TV.
look on the power supply board for burned parts. The board that controls the back light may have some burned parts as well.
Jul 05, 2015 | Samsung PN59D8000FFXZA - PN59D8000 59 3D...
Lg plasma tv 42PA4500 no picture
1) Make sure it is plugged in
2) check the power cord to make sure it is tight on both ends
3) plug something else into the wall outlet to make sure that it is working properly
3) If the power light comes on than it is not a power problem, check the cords to the cable TV or to the DVD player, or whatever it is you are trying to watch
4) If the power light comes on but the screen is black, use your remote to make sure you are on the correct input channel to watch whatever you have hooked up to the TV. For instance, if you are watching cable, and it is plugged into input 4, you need to make sure that you have input 4 selected or else you will get a black screen.
Jul 30, 2014 | LG 42PG20 42 in. Plasma HDTV
SDTV CONVERTER BOX BLACK SCREEN MENU WONT COME UP
Maybe pressing the SETUP button the remote will get results.
Nov 28, 2013 | Magnavox TB110MW9
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Samsung plasma all black screen
Black Screen come from three areas. 1- Power Supply Board 2- Inverter Board 3- Processing Board on the LCD. Since the Power Supply Board was replace, it easy to troubleshoot where the problem. lies If you cannot get the backlight, then its the inverter board. If you can use a flash light on the TV screen and can barely see the images, then the problem is indeed the inverter board. If you cannot see any images when using a flash light, then the problem comes from the LCD processing board. Let me know if you have any success. Mike
Feb 21, 2009 | Televison & Video
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Blank screen
I repaired mine. It had the same problem. Could be power supply. If you open it then maybe I can help.
Nov 30, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
143 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
