Question about Dremel Variable - Speed Multipro Rotary Tool 395
The variable speed switch on my dremel 395, can I get rep. parts
The contacts are all burnt. I can't get it to run on the high rpm side.
  • 2,176 Answers
The part number you need is 2610945681 variable speed switch. I checked a couple site with no luck but I suggest you call Dremel at 1-800-437-3635 and order direct. Good luck
Posted on Jan 10, 2009
Was able to acquire a new switch.
Dremel 395 Rotary tool won't turn on or won't stay on but a second or two
Electrically speaking there are a few items to check.
1) The easiest is to remove the two brush holders screws on each side by the power cord. If one of the screws are loose, or the bushes are worn you will get intermittent or no operation.
2) Second use a volt ohm meter to make sure you have voltage on the two brush connectors inside the brush holders when power is on. If you do then open the unit a check continuity on the motor armature to see if it is open, which will cost $13.37. If you do not have voltage, inspect the power cord and switch.
Some parts can be purchased on the below link.
http://www.ereplacementparts.com/dremel-395-f0130395ca-corded-multitool-parts-c-15440_15456_15474.html
Or contact a dremel service center from the link below.
http://www.dremel.com/en-us/customerservice/ServiceAndRepair/Pages/default.aspx
Apr 27, 2011 | Dremel Variable - Speed Multipro Rotary...
My Dremel 395 type 4 does not run until I spin the chuck and then only runs at high speed.
Sounds like a switch or brushes. You can go to Dremel.com and they have a toll free number for their tech services and you can also download a breakdown for this tool.
Jul 13, 2009 | Dremel Variable - Speed Multipro Rotary...
I own a Dremel model 395 type 5 variable speed and it suddenly stopped working. I was wondering if it was common for the switches to go bad or if it's known for other parts to cause it not to turn on.
I would recommend going to Dremel.com and asking their tech section about this. I have one also and mine works fine other than a small amount of heat at the spindle area.
Jun 17, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Need new variable speed switch for dremel 395 type 1
Someone else recently asked the same question and got the following solution;
http://www.fixya.com/support/t1515699-variable_speed_switch_dremel_395_get
Jan 29, 2009 | Dremel Variable - Speed Multipro Rotary...
Variable Speed Does Not Work - Model 395
It probably can be replaced. For info on this tool call 1-800-437-3635 (Dremel) and speak with customer service about a replacement part. Hope this helps
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Switch
Definitely not Home Depot. Try googling 'dremel model 395 switch', you'll probably come up with something. If not, there's always dremel themselves. This is a current model so there shouldn't be any real problem getting parts.
Sorry, don't know about installation, but I can tell you most of these dremels are real easy to fix in general, not complicated at all.
Jul 20, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
1,555 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
