My guess is injectors. The early duramax's had a lot of injector problems. They sometimes get to where they bleed constantly, and sometimes they break off... bad stuff. Check your oil for diesel. When my dads injectors when out on his 01 D'Max, his truck would run ok for a while, then lose power. Computer will cut power when it picks up an injector problem. BTW, Sightseer, diesels dont have spark plugs, however, the diesel filter is a good idea, you have to change them pretty regularly on the D'Max engines ( in order to try and prolong the injectors lives, mainly, the smallest bit of junk in your fuel can screw those early injectors up quick) I think they got the injectors mostly straightened out in the 04 models, what I've heard is thats the best model Duramax there has been, fuel economy, power, and reliability. Too bad all the year models arent that way :/
I have the same problem in my motorhome that has the same engine. I found a whole in one of my muffler, that didn't fix it. Now looking into spark plugs, fuel filter and new gas cap. I hope it isn't the injectors. I will also check my fuel pump pressure at the fuek rail.
