Question about Canon BJC 7000 InkJet Printer
I have the same problem but five beeps.
I refilled color catridge, I replaced color catridge but printer still does not work. Is it any way to reprogram printer, so it will work only on black catridge?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Printer says cartridge is out of ink but is practically new and hardly been used
Is it the original Hp catridge or you refilled it..???? you've replaced the black... so no problem with black.... color catridge would have dried... so remove th color catridge and wipe thi lower part gently with a wet cloth....!!!
Mar 23, 2012 | HP DeskJet 6988 Printer
Printing turns green
Your color i.e. Yellow & Cyan were functioned well but Your Color i.e. Magenta is not functioned will.. so remove the catridge and refill the Magenda and after refilling rub the catridge head with a soft paper untill the magenta is over flow.. after that your printer will print better. .. thanks
Aug 26, 2011 | Canon Pixma MP500 All-In-One InkJet...
Replaced the ink. black works colored does not.
Normally, new catridge has a thin layer close the output of the ink. See that thing. If it close, pull it over, Or.
May be the catridge is not suitable with the printer.
May be the the catridge is quite old and the ink is dry, if it is refill catridge, put several drop of hot water in it.
Hope this may help.
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Printer still won't work after refilled cartridges
let me know the printer company name..........................
try this............: align your catridges.
wash the both catridges with water & safely rub with soft cloth.
Feb 03, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My deskjet 840C printer wll not print green
cos green color is out. what u do is refill the color catridge or rather buy a new color catridge n ur up again.
hope u find help here
thank u
May 21, 2008 | HP DeskJet 840c InkJet Printer
Refilled color cartridge for lexmark Z845
The only work around to this is to use two catridges(2 color and 2 black and white). The reason is the printer has a mechanism to check if the same catridge is being used again. SO when you have two cartridges when one is finished refill the other and use and vice-versa. This way you will be able to refill and use for ever without any problems..
Regards,
Eagle338.
Mar 13, 2008 | Lexmark Z845 InkJet Printer
Lexmark z845 ink refill problem
eagle338
Rank:wizard_s.gif Wiz
Rating: 79%, 740 votes
Regards,
Eagle338.
Jan 16, 2008 | Lexmark Z845 InkJet Printer
Canon BJC 7000 InkJet Printer Logo
67 people viewed this question
old marine
old marine
