Question about Sony Playstation 3 (PS3) Console
No audio on games.
My playstattion3 plays movies fine, however I get no audio on my games. It has been working fine.
My sound on my laptop works fine but when i try to play a movie on it the sound is messed up but the movie plays fine whats wrong with it?
It could be a potentially corrupted movie file or disc. If it is a disc, examine it near a light source to check for scratches; also, consider testing it in a DVD player of some kind, and determine if the audio problem persists. Otherwise, if it is a file, try using another program to play it, or find another copy. If the audio problem persists for all movies, consider changing the program.
Dec 09, 2012 | Computers & Internet
My ps3 console will not play game discs for some reason! It will play movies just fine but not games HELP!!!!!
The Playstation 3 is a wonderful video game console, however, with heavy usage, the laser does eventually burn out. The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the game will stop reading altogether (even though movies sometimes still work). Eventually movies will stop working and the whole laser will eventually die.
The following website sells PS3 lasers and also performs repairs:
http://store.richspsxparts.com/pl3isnotrega.html
Jun 17, 2011 | Sony Playstation 3 (PS3) Console
Sound doesn't work while playing a game or movie from Xbox 360. It used to work - then it just stopped while a movie was playing. now games and movies won't play sound. Cables are good, sound sytem is...
You can figure out real quick through isolution what the problem is and who to point the finger at. Go ahead and unplug your xbox 360 system and hook it up to another tv. It doesn't have to be hdmi, just a standard one can work fine so you can plug the yellow video, and two white/red audio cables in to test. If that works then you need to look at the ports on your tv or sound system as the source problem. Check the settings...it doesn't hurt to reset them and reconfigure. Also check the xbox system settings in the Dashboard and verify. That will get the ball rolling and get your solution asap. Good luck!!!
Please rate and comment!!!
Dec 23, 2010 | Microsoft Xbox 360 Console
BOD problem
Depends, if u pirated it, its a virus, trojan prolly, if you bought it legally something might have interupted the download, skipping a file code, reinstall.
Oct 06, 2009 | Video Game Consoles & Games
Will play games but the audio cuts in and out
the audio skipping like that mean that the wires are shorting or frayed... you will have to replace your audio cords. Just as a note if this doesnt fix it theres a chance its inside the ps3 or just your audio reciever. Oh, before you go buying the audio cord try messing with the audio setting in the menu first, it might just be your audio sampling is set too low
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Very low sound when playing a movie.
You have to let the PS3 automaticly check sound after setting up HDMI. Redo the Video setup and let it do everything automaticly. Might check audio settings on the tv its self.
Mar 14, 2009 | Sony Playstation 3 (PS3) Console
Choppy Video Playback
it's probably the codec you're using. divx works nicely.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
My XBox 360 plays video but has no sound
Put the Hd video cable in the slot and put the regular audio cables in their slot. It should work then.
Dec 16, 2008 | Microsoft Xbox 360 Console
Blu ray not playing on ps3
Could be an overheating issue.. Is there enough air circulation around the unit? Is it possibly dusty? try and perform minor servicing (use a can of compressed air incase if there's dust causing problems)
Does this happen on regular dvd's ?
Jun 15, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
