SOURCE: My Kenmore washing machine, model number 26812690,
if its a direct drive , make sure the brake is releasing for starters, If the spin basket has difficulty getting up to speed, you have a slipping clutch. You can determine this by slightly holding the spin basket when you select spin.A rapid spin up to speed shows a "good" clutch. other things to check for are a broken coupler, or any item trapped between the drum and housing, ( which is what happens most the time, )
SOURCE: kenmore model # 110.23832100 Washer would
sounds like it's in the re-assembly since the water pump is directly connected to what you just did. take it apart once again and make sure all is put back right and water pump is properly seated on motor shaft.
SOURCE: the water in my front-loaded
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
SOURCE: HI I HAVE A KENMORE
you forgot the first three 110.82881100 is the full model,you'll need that to order the right parts.it sounds like you have a broken lid switch,i looked up your machine and it takes the older cherry switch part number 279347 and it's around 35 dollars.close the lid down,then open it around an inch or two,do this a few times,you should hear a clicking sound,if it isn't clicking the lid switch is broke,i'll send you a video from utube but it's for a different lid switch but you take the machine apart the same way but it's for a 247 lid switch and you need a 279347.if you can hear the motor running and this is happening you could have broken the motor coupling and i'll send that along too.http://www.youtube.com/watch?v=MFsvLiuTniU this is for the lid switch copy and paste.this is for the motor coupling http://www.youtube.com/watch?v=9K1KHEogf3c hope this helps salde
