Question about Reddy R155D Utility Heater
Fan motor turns half way then gets stuck
This reddy heater 115htr was a christmas present. when it is plugged in it hums . The fan motor turns half way and then gets stuck. If you use your finger and spin it it takes off. It should be under warranty. Please Help
  • dkdurben Jan 10, 2009
    We live in Albert Lea MN. 56007 . Were is the closest place to take it back. Thank You
  • bubba k Jan 15, 2009
    I have the same heater with the same problem. Heater only has a few hours of use. Heater won't start. If I lift the lid and spin the fan by hand, then I can plug it in and it will go just fine for 3 or 4 starts before the problem repeats.
    Problem Solver:
  • 7 Answers
Start windings in the motor are bad, and the motor should bereplaced under warranty or heater returned to the store.
Posted on Jan 10, 2009
  • Reddy Master
  • 3,253 Answers
Yes it should fan is sticking needs to be taken back
Reddy heater 55,000 blower fan runs slow or not at all and then kicks off the power
Hi, first unplug the heater, then remove the top so that you can see the fan motor. Try to turn the fan by hand. It should turn fairly easily. If it doesn't, try lubing the bearings. 3-n-1 makes an oil bottle with a long spout that can reach inside the motor to the bearings. If you don't have any, try some WD-40. If that works then you can get some oil as the WD-40 will be very short term. If this doesn't help, remove the filter cover from the back of the motor. Then loosen the 6 screws that hold the other half of the filter cover to the motor but don't remove them. Now check the motor and see if it turns freely. If it does then the problem will be in the air compressor. Tilt the motor toward the fan to prevent the fins from falling out of the compressor rotor and remove the 6 screws and the filter cover from the back of the motor so that you can see the compressor rotor and look for anything that would cause it to bind up. It could be from buildup on the part you removed or behind the rotor. If none of this frees it up you will probably need a new fan motor. Let me know what you find and if you need any help finding a fan motor.
Jan 11, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
It just hum when you try to start it
Turn off the power and remove the top cover. Try turning the fan motor by hand. If it is hard to turn, try lubing the motor bearings. If this doesn't help, remove the filter cover on the back of the motor. Now loosen the 6 screws that hold the other half of the filter holder to the motor and check to see if the fan turns easier. If it doesn't you probably need a new motor. If it does the problem is with the compressor rotor. Watch out for the fins that can fall out of the rotor and remove the filter cover from the back of the motor. If you tip the motor toward the fan the fins will not fall out. Inspect the rotor for anything that would interfere with the rotation.
Jan 10, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
My Reddy heater torpedo multi fuel heater won't start this year. It makes a loud humming noise for a minute or so and then nothing. If I try starting it a few times in a row it will make the noise...
Remove the top cover and rotate the fan by hand. If should turn pretty easily. If not may you can put some oil where the shaft passes through the ends otherwise you will need a new motor. If the fan turns easily then the capacitor is probably shot. I don't know if you can get the capacitor seperate from the motor or not. There is a small low pressure compressor attached to the back of the motor. Your problem may also lie in there. The covers come off easily so you can check it out.
Dec 29, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Hums but wont fire
Remove the top cover, plu it back in and see if the hum goes away, if it
doesn`t look to see if the fan is stuck, if it is unplug and try to spin it
by hand, if it wont spin replace the fan motor
Feb 12, 2010 | Reddy Heating & Cooling
Kersone reddy heater won't start, just buzzes
The R150B uses motor #097308-06, has a split phase motor. The secondary windings, which give the armature a jump-start, have gone bad. The motor is not serviceable. Try reddyparts.com - they seem to have the most parts.
Feb 22, 2009 | Reddy Heater-30-55,000 BTU Variable
Heater won't start
Thanks for your question,
Sounds to me like you have a faulty fan in the unit, could be stuck, or might be a bad fan motor, try unplugging it first, find something to insert where the fan is and try spinning the blade, if its stuck or has alot of resistance, then you have a bad motor, if its free spinning, then try plugging it back in and see if it works, sometimes just by manually moving the motor shaft it frees it to work, if it still doesnt work, then you might look at replacing the fan motor, or replacing the unit, hope this helps ya,
mr.grzz
Jan 25, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Kerosene forced air heater will not light, only hums.
Your problem may be as simple as the vanes of the rotor stuck to the pump body, or a rats nest binding the fan blade, or the starter relay being defective (if equipped ) . On the other hand, the bearings in the motor could be frozen up. The motor is not servicable and must be replaced. Start by disassembling the air pump, remove the vanes & rotor, then attempt to start the motor. If it still hums, then you have motor or relay problems.
If the vanes were stuck, clean it up, reassemble (no oil) , set the pump pressure.
Oct 29, 2008 | Reddy Heating & Cooling
Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Dec 06, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy R155D Utility Heater Logo
470 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
