Question about Music
I have a set of peavey scorpion sp5xt's one works fine but if i plug into the other one ,in full range, only the horn works,
Horn and speaker combo cabinets have an electronic component called a "crossover". The horn and speaker both work off different electrical signal frequencies. If you can take off the back, or get inside by pulling the speaker, check for a small circuit board mounted inside the box or on the speaker or horn. Check for a broken wire or loose connection of the crimp connectors.
A common problem with speakers, often the cone, or paper part of the speaker will come un-glued or separated from the magnet "voice coil". This happens when played too loud, when it's commected to the wrong impedance, or if the signal was shorted and "overdriven" (usually sounds like an awful buzz that's really loud).
Always make sure your output impedance matches the impedance of the speaker. Most auto stereos are 4 Ohms. Older home stereos are typically 8 Ohms. Musical PA gear varies between 4, 8, and 16 Ohms. Peavey gear is typicall 4 Ohms, but some older models are different. The Ohm rating is the amount of the resistance in the circuit. If your speaker is 4 Ohms and you plug it into an 8 Ohm circuit, you can destroy the speaker and sometimes the crossover circuit board.
Good Luck.
Jim
jimmydsmith@cox.net
Phoenix, Az
Posted on Jan 10, 2009
# 1991 peavey classic chours 2x12 scorpion speakers one speaker makes a buzz noise only on a high e note only sometimes -if i want to replace the speaker do the front grill come off to remove spekaer
Normally on older Peavey amps the grill is on a frame attached to the face held on with velcro. I suspect you have something vibrating against the speaker if it's only one frequency. Once the grill is off it may be apparent.
Also on old Scorpions and Black Widows Peavy has a piece of foam in the hole in the magnet to keep junk from getting in the speaker. Over time it crumbles and opens that hole, but even worse can get it the gap and freeze the voice coil. I always suggest cleaning it out while the speaker is out of the cab.
Nov 12, 2016 | Peavey Music
I have a pair of peavey sp-2xt speakers if i use the full range input the horn would not work but if i plug it direct to the hi input it works .any sugestions to fix problem thanks
There is possibly a bad solder connection or component on the crossover. I cant remember if that crossover uses a 12volt light bulb or not, for DC current protection, if it does make sure the bulb is good.
Jan 11, 2015 | Peavey Music
Horns dont work on both sp2 ti
diaphrams, the high input is a direct connection the the horn.
Jan 15, 2014 | Peavey SP2 PA Passive Speaker
Peavey sp2xt speakers horn makes no sound when plugged into normal input. Horn works fine when plugged into the high side of the crossover.
High side speaker input jack defective, as they are switch also and if you plug the wire from the amp in full range and no hf sound but connecting directly to the bi-amp hi does, then your female 1/4 plug at crossover is defective for sure.
Jul 28, 2012 | Peavey SP2 PA Passive Speaker
Peavey xt22 horn not working
Across the diaphram you should be reading about 8 ohms. it sounds to me like it's blown.However,if you think it'ds thre crossove, take it out and send it to Peavey. They do good , fastwork.............................................................
Mar 23, 2017 | Music
Peavey SP3 (older model) Can not get any sound thru horn.
They have a "soundgard" protection network that uses a polyfuse and an automotive lamp. Open the unit and check the circuitry. Both the polyfuse and he lamp may be blown. Do ohmmeter check of these, otherwise the horn is blown.
Aug 08, 2011 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
I have a 12" Peavey
The voice coil is probably damaged. You can get replacement basket that has the cone, basket, and voice coil for under $100 and put the old magnet on it. Reconing costs as much... you can change the basket in 5 minutes. Sometimes the voice coil partially separates from the cone or you can see it has overheated when you take the magnet off. Be careful not to get contamination in the magnet asembly. The basket is part number SP12825 RB for a 12 inch 8 ohm type..
Jul 22, 2011 | Peavey Scorpion SP1525 Loudspeaker
No sound in horn when plugged in bi amp connection
The question is whether or not you get any sound from the horn when in full-range. If so, then either the input jack for the horn is defective, or you are not passing the signal. A quick check would be to send the full-range signal (at low volume) to the high-freq input. You should hear the horn work. If not then the connector is defective on the crossover board.
If you get no sound from the horn in any configuration, then the coil is blown for the horn. This can be replaced. It is usually a 22a or 22ti diaphram
Let us know what you find.
Dan
Dec 09, 2010 | Peavey SP2 PA Passive Speaker
In the wirring is there any way of making the amp produce a high out sound rather than full range
Unfortunately range and power are not correlated. Good amps have a full range, cheap ones do not....range it not related directly to power output.
What are you trying to accomplish exactly?
Thanks!
Feb 03, 2010 | Peavey Pv 2600 Power Amplifier
Music Logo
258 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
