Washer not working
Yes there is black crumbs under the washer
  • Bill Dozier May 11, 2010
    top loader or front loader and how old and name brand please so i can help you more does it make any noises?? tell me what it is doing (problems) etc... thanks bill
Yes found out i needed a coupler.thank you
Posted on Jan 10, 2009
Why did it suddenly stop working?
The Auto Head Quartz Control or the quartz heating element failed.
Nov 29, 2015 | Bosch Styline Collection Toaster...
How to clean the inside of a toaster
Slide the bottom door under the toaster and it will open, I would suggest doing it over a waste can or sink. You can take a small thin brush and get the crumbs out. Then your toaster will be back in working order. Crumbs that are stuck in the bottom of the tray is what causes it to burn the toast.
Nov 21, 2013 | Dualit CTS4E 4-Slice Toaster
Pro pressure washer 3200psi will only pump soap if lance is disconnected?
yes they will not draw soap under pressure use the large black nozzle or no nozzle at all
May 20, 2012 | Garden
The enter key on my 9-month-old Acer netbook has stopped working. I'm running a full scan as I type this and I've upgraded to Firefox 4 with no success. Is the key just worn out or is it a software...
This is likely a hardware problem, and not related to any of your software.
Keyboards take a lot of abuse and can wear out or get jammed. Crumbs from food, or dust, etc can also get lodged under the key. Fortunately the keys are removable, but you must be careful when removing them from the laptop (the plastic pins that hold them are delicate).
Using a table knife, slide it under the edge of the Enter key. Twist the knife a little to lift up one end. Twist gently until you hear a click as it comes loose. Be gentle and proceed slowly. Some Enter keys have two clips, so you may need to pry up the other end of the key too. Some keys also have a thin metal bar/wire. Notice how this hooks up, because you'll need to put it back together this way.
Look for any hair, crumbs or other items in the space under the key. Also, make sure the plastic/rubber spring-pad is working properly by pushing down on it. If you push on the spring-pad with a pencil (erase end), does the enter key work (open up Notepad or Word while you test this).
If yes, try putting the key back on the way it was. Hopefully everything should work now. If not, make sure you clicked it back in all the way, and that it is seated properly.
If it still doesn't work, there may be other problems with the key, and the best bet is to have a qualified technician take look. Take your system to wherever you bought it, or Best Buy for service.
Apr 04, 2011 | Computers & Internet
I just installed an American Standard easy touch faucet 6310F. The pressure is very low. Anybody know what the problem may be?
At the base of the handle there is a flow regulating check valve. Shut off water supply and unscrew handle and look for debris. Many times the washers break down on the shutoffs under the sink and release "crumbs", these usually block aerators and sometimes the cartridges on certain faucets. Hope this was helpful.
Feb 16, 2011 | American Standard Kitchen Faucet 6310 020...
Sometimes my computer shows that i can't go any further as i haven't enabled the cookies. What are cookies? Are they safe? I seem to need them; do I?
Cookies are data crumbs left by web sites you visit.  That is how they know what your interested in and give you suggestions based upon your browsing history.  They are also used by your computer to load data faster because some of the information for the web page already resides in the computers memory from the last time you visited.  You can delete cookies if the information is outdated or corrupt or you don't want to be tracked, but the web site will take a bit longer to load the next time you visit.
Nov 15, 2009 | Computers & Internet
Breather for the dish washer
Yes the breather can be placed under the sink. Just be sure to mount it above the level of the dishwasher. You can either screw it to something wood or use tie straps to tie it up to a screw.
Mar 01, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Crumb Catching Design
Yes, this design catches all knids of things but it keeps those "crumbs" from getting inside the door facing. This also acts as an air relief for the oven.
Jan 24, 2008 | Jenn-Air JJW7530DDS Electric Single Oven
I can't hear people, but they hear me. V3 RAZR
see nicole what could have happedn ur phone's default speaker must have gone bad, so what u can do u can try to check out the connectivity with ur main chip and than try otherwise change the speaker.
Oct 19, 2007 | Motorola Mobility RAZR V3
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
