Question about Emerson Smartset Clock Radio
Alarm clock came with chinese instructions manual,I need English
I purchased this alarm clock and the instructions came in chineese, and I have no clue how to operate or set it now. Where can I get the instructions in the english language from?
The product is a ''Highstar projector LED clock and the model # is HSD128A''
Hope you can help me~
HSD128A LED Display Projection Clock (Black)
Sandra Quirino
  • 3 more comments
  • king12345 Jan 16, 2009
    HSD128A clock came with chinese user manual.
    Beautifull door stop.
    Marcel
  • tef555 Mar 20, 2009
    so how do you keep the projector on all of the time
  • patfradley Mar 30, 2009
    I have the same problem with HSD128A projection alarm clock. I managed to set the clock but then when Itried to set the alarm and the date I kept losing the time, and had to keep re-setting it. It is very frustrating, not to mention time consuming.They take English money but supply chinese instructions
  • Anonymous Apr 25, 2009
    I have the same problem with a Projector Led Clock model: HSD128A which I bought on eBuy from Hong Kong adverdised with an english instruction manual but it came with a chinese one.
    could someone tell me where I could get a english or german instruction manual for this clock.
  • Keren Roy
    Keren Roy Apr 16, 2014
    Free pdf download http://download.meritline.com/2011_6_1_1...
1.slide "return to time"to off, slide "backlight" to on
2.each press of the mode button goes through "time, temperature, year, month(M looks like an H) and day(D), alarm1, "2, "3, , Birthday Celebration, countdown/stopwatch"
3. when on the category u want to change, press and hold set button for 3 secs, adjust with up and down and the hit set when done with each adjustment
Buttons on the bottom in order from left to right are(buttons on the top part of the clock bottom when turned on its side) mode, set, up, down
Posted on Jan 23, 2009
    President:
  • 814 Answers
The buttons on the clock are from left to right. 1.Mode Button. This button will be used to cycle the clocks functions. [1. Time 2. Temperature 3. Year. 4. Month (The M looks like an H) 5. Day (D) 6.Alarm 1 7. Alarm 2 8. Alarm 3 9. Birthday celebration 10. Countdown Clock/Stopwatch.] 2. Set Button. This button will be used to set all times and date functions in combination with the up and down buttons. When you want to change a time or date, Hold down the Set Button for about three seconds and do the adjustments with the up and down buttons. 3/4. Up and Down Buttons. These buttons will be used to change the dates and times. This will be done by clicking on the desired up/down function of the change you want to make for the function. The Slide control is used for turning the time display "backlight" function off /on. The company web page for customer support is [http://en.highstar.com.cn/newEbiz1/EbizPortalFG/portal/html/index.html#] copy this link and paste it into the address bar of the browser. It will take you to the HighStar home page. I hope this information help you with operation of your HighStar Clock.
Posted on Jun 12, 2009
The projection light switches off after a few seconds... how to make that permanently light up?
Posted on Jun 05, 2010
Follow this link to find the instructions in english :
http://www.tinxi.com/download/88028_en.pdf
and this link to find them in german
http://www.tinxi.com/download/88028_de.pdf
You'll find all that you need.
Posted on Jun 26, 2009
  • Abdulrahman Zeyara
    Abdulrahman Zeyara Nov 26, 2014
    Please reload the PDF file in English again, the file not found any more. "The requested document was not found on this server"
    New Friend:
PDF free download
Posted on Apr 16, 2014
    New Friend:
Is there a way to turn off the alarms? It keeps ringing and I have no idea how to turn it off. Need help. Thank you.
Posted on Oct 09, 2015
    New Friend:
To make it light up all the time (not with batteries).
You need to remove the battteries and remove screw in battery compartment.
Warm front of display with hairdryer and peel off (glued on).
Remove 5 screws.
Pull display out of casing box.
Insert a new think wire between black wire on projector and - negative terminal of the white LEDs for display. (Google LED symbol and match with symbol on PCB board to know -ve)
Make sure the new wire doesn't cause a shadow with projection of the time as it bounces off a mirror in the bottom of the clock!
Posted on Oct 28, 2014
    New Friend:
I have a HIGHSTAR HSD110B,i did it
thank you so much!
Posted on Dec 29, 2012
    New Friend:
Hello, I bought the Highstar HSD1140 projector alarm clock for my Nan for Christmas and it did not come with a manual at all (English or Chinese). Does anyone know where I can find a manual to help me set up and understand the clock? I thought I had set the alarm correctly but sometimes it works and others it doesn't. I know that M is mode for navigating and S is for setting but I am not sure what mode is what etc.
Sorry for sounding a bit dumb :)
Posted on Jan 20, 2014
SOURCE:
SEIKO ALARM CLOCK SQ767W MANUAL i GOT TWO OF THEM AND THE INSTRUCTIONS ARE IN CHINESE
The normal clock/alarm functions of the Seiko SQ767W work worldwide, but because the feature that automatically sets the time via radio signal only works in Japan, Seiko only provides the manual in Japanese.
https://www.seiko-clock.co.jp/product-personal/digital/temperature/sq767w.html
https://www.seiko-clock.co.jp/product-personal/up_files/FSQ-125P.pdf
Here's an English version I made with the help of onlinedoctranslator.com (uses Google Translate). I made a couple of adjustments but it's still pretty rough due to the machine translation.
https://1drv.ms/b/s!AKpNuPb-kshMyTo
Mar 08, 2018 | Seiko Watches
Control pannel
Is the operating system completely in Chinese?
If so, it will need to be reinstalled from an english disc.
Nov 23, 2013 | Toshiba Computers & Internet
I purchased an RCA Radio/CD player, with the manual showing the numbers RP5605 and RP5605R on it. However, I cannot set the clock, alarm, etc. because everything in the manual's instructions is NOT in
To use the worry-free backup battery, get a 9V battery. Then look for the battery compartment on the bottom of the unit. Press the tab with your thumb and then lift the cover out and away. Plug in the battery and then replace the cover.
Press Wake Time once and use the forward/reverse buttons to set the alarm time. Then press Wake Mode repeatedly to toggle between the options of wake to radio, wake to CD, or wake to alarm. (Note the radio must be tuned to your desired station and a CD needs to be in the player for these to work).
The Smart Snooze means that pressing Snooze, forward, reverse, play or stop will turn off the alarm temporarily. (Pressing Off will prevent the alarm from sounding again today.)
The English version of the manual for the RP5605 clock radio is available here: http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/RP5605.pdf .
I hope this helps.
Dec 17, 2011 | RCA Audio Players & Recorders
How do i change my lg phone chinese language to english?
Get an identical one from a friend, and follow the instructions to look for languages in both phones, when you get it on the 1st, do it on the Chineese one
Mar 07, 2011 | LG Cell Phones
User manual in Chinese
There is a website, which is specialized on english manuals for chinese phones. Check it for your model or send them a search request.
Jul 22, 2009 | Nokia Cell Phones
How to convert chineese to english in nokia e55i
Hi Friend,
Kindly follow the below mentioned steps and convert the Chinese language to English
1.Select Menu
2.Select Settings
3.Select Phone Settings
4.Select Language Settings
5.Select Phone Language
6.Now Select the English Language from the List
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
Jul 18, 2009 | Nokia Cell Phones
HSD128A projection clock came with chinese instructions
Here is the PDF of instructions. http://www.tinxi.com/download/88028_en.pdf
Mar 30, 2009 | GPX D725 Clock Radio
IP9300 Manual
www.ningbo.esiti.net
down load the english version & u can get the english version
Additional features Language: English - Chinese LCD Size: 3.0 inch, 3.5TFT, 260 thousand colour; PX: 240×320px Ringtone: 64 chord; Ringtone format: mp3, midi, wav Music: Support mp3 as the coming call ringtones.Loudspeaker is good. Video: 3GP,MP4,Support 3GP/MP4 full screen play Camera: 2.0 megapixel; 2cameras,640*480photograph,support video recorder. Rom: 1G internal card Data Transfer: USBdataline/U board/bluetooth stereo play/document bluetooth transfer Standby Photo: jpg, gif Main features Telephone directories: Up to 300 phone book entries,support coming call movie play,mp3,photograph Messages &Multimedia messaging: 100SMS/MMS Schedule power on/off: Automatic power on and off Alarm clock: Support alarm clock as power off Games: More information: MP3, MP4, Handsfree, SMS group sending, Voice recorder, WAP, Handwritten input, Handwritten + keyboard input, Bluetooth, GPRS download, MMS, 2GSMs, IPdial, 2vioce recorder.......... Basic features Operating Frequency: GSM Network Frequency: 900/1800MHz Talk time: 240-300Minutes Standby time: 180Hours Time-to-market: 2007.05 Shape: PDA Dimensions (width × high thick): 117*65*17 Weight: 125G Color: Black
Jan 23, 2008 | Samsung SGH-E900 Cellular Phone
Emerson Smartset Clock Radio Logo
15,281 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
