Question about Minolta XG-A 35mm SLR Camera
I cannot wind the camera
I just recently bought a Minolta XG-A and I found out that I cannot wind the camera at all even when the camera is turned on. I bought batteries because I thought it was dead, but the same thing happen. I could not turn the rewind crank and I could not take a picture. Please Help!
    Scholar:
  • 185 Answers
Yellokp13,
if the led's light in the finder you have a mechanical problem.
if the led's don't light in the finder then turn the shutter select knob left & right around 5 times do this also to the off / on switch. remove batteries and clean the contacts with pencil eraser.
if the leds still don't light then you have a flex circuit problem.
i am assuming there is no film in the camera.
if you decide to have the camera repaired get an estimate first as there are no new parts available.
Posted on Jan 10, 2009
I just bought the minolta XG-A, will I be able to adjust manually the shutter speed? I just bought it only, still has not been shipped. I bought it mainly for a film photography class but I just read that...
Minolta XG-A can work in full manual mode. The lowest shutter speed is 1 second and it had Bulb mode where the shutter is open as long as you press the button.
Sep 12, 2013 | Minolta XG-A 35mm SLR Camera
How do i load batteries into my minolta xg-a camera
Use a coin to unscrew the battery cover on the base of the camera.
If you need a manual, you can download one from
http://butkus.org/chinon/minolta/minolta_xg-a/minolta_xg-a.htm
The battery replacement instructions are on page 12.
Aug 12, 2011 | Minolta XG-A 35mm SLR Camera
Does the minolta xg-a have to have batteries to use the view finder? if so, what kind of batteries does it take
The XG-A requires batteries, not just for the viewfinder, but also for the shutter. It uses two alkaline A-76 (or equivalent) or two silver-oxide EPX-76 (or equivalent).
If you need an owner's manual, you can download a PDF version from http://www.butkus.org/chinon/minolta.htm
Feb 16, 2010 | Minolta XG-A 35mm SLR Camera
My camera will not advance to the next frame and
Hello. Sounds like the camera needs new batteries.
Jan 18, 2010 | Minolta XG-A 35mm SLR Camera
Strange Foggy line across view finder of Minolta XG-A
sounds like liquid damage. take the bottom cover off and see if there is any rust or corrosion. if all is ok and the camera is working, don't worry about it. it has no effect on print quality.
now if you find rust or corrosion your camera is about to become a fancy paper weight. not repairable economically.
Jul 18, 2009 | Minolta XG-A 35mm SLR Camera
MINOLTA XG-1 & XG-9
If everything lights in the camera when you test it ,it means the battery is alright,try this trick"Rotate the film advance connection at the bottom of your camera using a nickle (not the battery compartment) the one directly at the bottom of the shutter and should click if there's not you have some bigger problem.Good luck.
Sep 30, 2008 | Photography
Minolta XG-se Camera Owners Manual
If you can find the manual for the XG it can be used. the se ( special edition ) is the same camera.
Aug 14, 2008 | Photography
Power
1. Remove the batteries and replace with proper alignment of POLARITIES positive and negative.
2. Turn on and off for two or three times.
3. Load the film in the champers correctly.
4. Aim the camera at the proper lighting objects and try with the different aperture and speed settings.
Mar 23, 2008 | Photography
Minolta XG-A 35mm SLR Camera Logo
272 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
