Question about Nvidia GeForce4 MX440SE 64MB SDR AGP with TV-Out Graphic Card
Conflict with memory allocation
I have the Nvidia card installed in a Deskpro 866 series running Win98SE in a SDR slot. The conflict reads no memory available - ACPI BIOS is using this allocation. When I try to change the memory allocations manually, windows does not let me. When I remove the ACPI Board Extension Driver that was causing the conflict, windows just reloads it on boot. Is there a solution?
Thanks,
Lew
  • 1,602 Answers
THAT IS A WINDOWS ALLACTIONS FILE AND YOU CANNOT CHANGE IT NOT WITHOUT REWRITTING THE WHOLE WINDOWS PROGRAM.
YOU MAY FIND THAT THE CPU MAYBE SHAING DMA CHANNEL OR IRQ WITH THE SAME ERROR
A BOOK I HAVE PUT A WORKING VIDEO CARD IN AND EVERY THING WORKS OKAY THAN THE PROBLEM IS NOT THE VIDEO CARD MORE LIKELY THE MOTHERBOARD DMA ERROR NOT YOUR VIDEO CARD
ROD
Posted on Mar 02, 2009
Resource Conflicts errors for PCI in Slot 01
hey carl - first thing - laptop or desk top - if desk top (tower) remove all slotted cards and boot system - when it boots completely to home screen. shut down and insert 1 card at a time until you recieve you nasty screen. or boot into safe mode f10 or12 get in and disable all your cards -windows system- control panel - then turn on one by one doing a reboot - when you do find the conflicting card you should be able to figure which card or cards they conflict to - you will have to change the resource allocations on probable 2 or 3 cards to allow all to work - there all lots of sites that will explain this better - hope this helped
Mar 20, 2014 | Sony VAIO Computers & Internet
I bought New GeForce FX 5500 256MB Graphic card,After inserting it in slot. It is getting hanged in the startup of Windows, or some time it is getting hanged at bootup up. not even able to go into safe...
Does your motherboard have an internal video card? if it does, go to system bios and turn it off. it might be a conflict between the internal video card and your AGP card. Lastly, have you uninstall the old video card driver software? before installing your AGP video card. there's a possibility that there's a video driver conflict. If it still doesn't work, it might be a hardware conflict,compatibility or failure.
Good luck,
Ryan
May 24, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
Resource Conflict - PCI network controller slot 03 and 04
I had this problem for almost a year. One day I decided to put it back t factory default, it work for a week and then the Error message pop again at boot. I installed windows 7 CR and after a week of working fine, same thing happen. I open my laptop, check everything, clean it, and nothing. Until I found the by pressing really hard on the slot where the conflict was, it work 9 out of 10 times I started my laptop. On my Acer the Slot 3 Conflict is where the memory card reader is, or atleast that is what I though. After taking my laptop to an IT Tech, he discovered that the Slot 3 was right next to the wireless network card, and by pressing the area reallu hard the computer will start 95% of the time. But when I say really hard, I mean really hard, as a matter of fact, while trying we even crack the bottom case.
The solution was one of two options:
1. Acer motherboard in certain models, it was defected, and it was known within the puclic, prompting the same Error Conflict that I have, so we would have to get a new Motherboard ($120) or
2. Take all the OS out of the computer, and Install an Linux OS like (Ubuntu-free) you might ask yourself why?
Because Ubuntu doesn't depend on the hardware to function. Windows does. Ubuntu is a self dependable OS, Unlike Windows.
#2 was my solution, it's been alamost 6 months and I never had the probelm again.
Mar 11, 2009 | Computers & Internet
Asus a8n sli premium
From the Asus support site.
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory.
Jan 06, 2009 | ASUS A8N-SLI Deluxe Motherboard
Conflict between geforce nvidia 7200 with MOBO asus p5pl2
i think you mean you don't see any post readings
you can go into bios setup
and set page to default settings then press f10 to save and exit
let me know if this helped
Dec 13, 2008 | ASUS P5PL2 Motherboard
Resource Conflict - PCI Network Controller in Slot 02
check for an update of bios on acer.com it will fix your laptop problem....
Apr 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
PCI Device Conflict
u can try to change in BIOS, the settings that manages PCI IRQ's. If it is on manual then put it on auto mode. If on auto mode than manualy change the allocations of irq for the pci slot no. 5 ....
Jan 20, 2008 | EPoX EP-9NPA7I (0819366003415) Motherboard
Graphics card
In order for Cold Fear to run properly, your PC must meet or exceed these minimum requirements:
Opertaing System: Windows 2000 / XP Only
Processor: 1 GHz processor minimum, (2 GHz recommended)
RAM: 256MB RAM minimum, (512MB recommended)
Video Card: DirectX 9 compliant 64MB (128MB recommended) see supported list *
Sound Card: DirectX 9 compliant
DirectX Version: DirectX 9 included on disk
DVD-ROM: 8X or better
Hard Drive Space: 2.2 GB
Peripherals: Mouse, keyboard, Windows compliant game pad.
* Supported Video Cards at Time of Release
Nvidia GeForce 3/4/FX/6 series (GeForce 4 MX not supported)
ATI Radeon 8500/9000/X series
These chipsets are the only ones that will run this game. Laptop versions of these chips may work but are not supported
NOTICE: This game contains technology intended to prevent copying that may conflict with some DVD-RW and virtual drives.
Also, make sure that no other programs are running.
Dec 09, 2007 | Computers & Internet
Nvidia GeForce4 MX440SE 64MB SDR AGP with TV-Out Graphic Card Logo
110 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Alun Cox
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
