Question about Sanyo DP42746 42 in. Plasma Television
Dead Sanyo DP42746
Our Sanyo 42-inch plasma just stopped working. No picture, no sound, no green light, no click, nothing. I have tried different outlets, turning it on with the button on top as well as the remote, and nothing happens. When it went out, our satellite DVR function also stopped working, so I think it may have been some electrical surge or something. Is there a fuse that we can get to and change? Or, do you have a clue what it can be?
  • 2 more comments
  • kussdk Jan 11, 2009
    Thanks for the suggestions! I took the fuse and power supply to Radio Shack, and they tested them both and said they're OK. So, is there anything else that we can check? We'll probably have to take it in to a shop, but it would be nice to have an idea as to what it might need.
    As I noted earlier, Radio Shack checked out the power supply and fuse next to it, and said they are both OK.
  • kussdk Jan 12, 2009
    The TV is nearly 2 years old and not under warranty. We were not using a surge protector. We removed the back and took the power supply and the fuse next to it to Radio Shack; both checked out OK. There are several other fuses; should we have those tested also? Any other ideas? Thanks!
  • kussdk Jan 13, 2009
    I have not received a response since I let you know that the fuse and power supply are OK. Please let me know what else it could be. We are waiting to hear from you before taking it to the shop.
  • 124 Answers
Try to flip the fuse on your circuit breaker it could have blown the power to that outlet just go to circuit breaker and flip all switches to the middle and test again hope this helps
Posted on Jan 13, 2009
    Genius:
  • 2,920 Answers
The simplest solution is to take it in and have it repaired..mostly here is going to be guesswork and no one can tell you for sure what caused the problem other than a possible power surge as u have suggested. when you take it to a shop they will give you an estimate of the fix and you have the choice to fix it or buy a new one. as i said mostly here you will get alot of guesswork and you need something concrete where you dont have to run around having parts checked etc.
Posted on Jan 11, 2009
  • Sanyo Master
  • 19,396 Answers
If the power supply is fine, and there is power on PSU DC connector on tv side, try gently moving the plug.
If the TV powers up then it is the DC connector that is soldered on digital control board (the main board).
If the connector does not make any change, then the unit must be taken apart.
If there is no power at all , then it is either a bad short inside or a defective digital board.
Ensure first that the PSU is working, and that there is power to the connector.
  • Ginko
    Ginko Jan 11, 2009
    I mean, if the panel is gone, you get blink code, same for all board, apart PSU that can die completely or return code.
    If PSU is fine, then the most likely is a defective digital board.
    You can find all replacement parts cost here: DP42746 (162)
    Sergeant:
    Scholar:
  • 199 Answers
If the fuse is ok and the board is ok.then it is definately the issue of bad or blown capacitors or ic on the main board that has to be checked with a meter to get it replaced.as that would not be too costly.but it needs severe checking of the board and for that a repair center is the best place to take it.
    President:
  • 1,990 Answers
Welcome to fixya! You have tried the only Fixes that it could be. Your next stop is an Authorized Service Center. Watch the Price of Repair Though!
    Master:
  • 416 Answers
Did you use surge protector. If yes look for blown fuse where.
If now you will need to remove the back cover in order to get access to fuse mount. But it will void the warranty if TV is still on warranty.
Repair manual is here
Good Luck
http://www.hdtvsolutions.com/pdf/DP42746%20MANUAL.pdf
    Sergeant:
    Novelist:
  • 326 Answers
Just check out the fuse on the main circuit board if it is blowned this happens.the fuse will cost you $2 to get.
    Scholar:
  • 160 Answers
Its the faulty power supply of your device .u will find the fuse on the powersupply it self
I have a Sanyo dp42740 plasma TV , the green light on front comes on for about 2 seconds and goes off. what is it?
Hi Gray,
Please try giving 13V from external source. When we exhaust all the options of changing boards we try such things to get the set working. I hope it helps.
Good luck
Aug 04, 2015 | Sanyo Televison & Video
Yes I have a DP 50749 sanyo plasma tv 50 inch the green power led comes on for 20 seconds goes off. then it sounds like relay on the main power board starts a clicking noise Then it stops clicking...
This is likely a heat issue, and the CPU of the tuner is instructing the power board to switch it off for reasons related to over heating. Check that a fan ventilation improves the problem. The solution is not easy but maybe adding a fan to the tuner CPU can fix this issue.
May 07, 2014 | Sanyo DP50749 50 in. Plasma TV
Sanyo 50" plasma flatscreen, hdtv
Picture frozen on one picture for some channels and blank on others. Sound is on. What could this be? We have a 50" Sanyo. HELP!
Apr 13, 2011 | Sanyo DP32746 32 in. LCD Television
Tv keeps turning on and off
You probably have blown capacitors on the PSB-power supply board. Recaping with new UF caps works 90% of the time. The set turns itself of into a fault protection to keep from damaging more components internally. A few bucks a soldering iron some solder should do the trick.
Jun 29, 2010 | Sanyo DP50747 50 in. Plasma TV
Sanyo DP42746.Can't get tv to come on. The green power LED is on.
unplug the power connector to the tv, wait two minutes then plug it back in and try to turn on the set... this worked for me.
Dec 20, 2009 | Sanyo DP42746 42 in. Plasma Television
Have sound but no picture on plasma green light is
check out for high voltage regulators near picture board. need servicing resoldering the whle unit and heated area..try it
Oct 27, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Sanyo DP50747 Replaced Power Supply still not working
I have same problem. Walmart is selling Sanyo junk You are not alone lots of web chatter about these lasting 2 years or less, Mine lased 19 months, Trash it & buy a different brand. I originally was going to buy a Samsung & now I will.
Sep 22, 2009 | Sanyo DP50747 50 in. Plasma TV
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Dec 06, 2008 | Televison & Video
No sound and black screen
lets get together, start a list of names and sue companies selling crappy wares at way too high prices! email saryejade@aol.com
Nov 09, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
42 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
