Question about E-Machines eMachines Desktop PC
Emachine t2042 I read a former post you had and did the entire process however, when i use my restore cd it tells me that it : cannot open R:T2042.GHO, cannot open GHOSTERR.TXT, Invalid Dump File. It says this in three sperate boxes with ok on each box in the order I listed them any idea whats wrong? The computer works but the picture is distorted and the USB ports are not working.
  • solutions4u May 11, 2010
    Are you restoring the system by overwriting and reformating the harddrive or are you using your restore cd in repair mode?
  • 54 Answers
*.GHO files are Norton Ghost images that are used by some OEM's to create a factory defuault image. When you restore this it should set the pc back to the same condition it was in when u purchased it however this will erase all your personal data on the drive.
If you are getting this error it means that the ghost image you are using to restore the PC is corrupted and cannot be used. eaither the CD is trying to read this data from a corrupted restore partition or the restore disk you have is bad (sometimes the disk may look fine- no scratches or anything and still be bad)
Try checking the disk for scratches or smudges but if you dont find any you can clean off the disk you will have to contact e-machines for a replacement disk.
Posted on Jan 24, 2009
Hooking up a Internal Hard drive
You probably need to give more details. If it's a replacement drive, did you reinstall Windows from a CD? Did you copy from the original hd? It's simple enough to remove the two cables from the original drive, physically remove and replace the drive, and hook up the new drive. But then you'd need to boot to a Windows CD in the CD/DVD player to format and install Windows, if that's what you're attempting to do.
There's possibly a recovery partition on the old drive )or a recovery CD). If so, you'd connect the new drive to a second power cable, and data cable (which might not be included in the tower) :
To restore system software from the Recovery discs:
1 Insert the Recovery disc #1 into the CD or DVD drive.
2 Restart the computer, then press and hold
R when prompted to display the restore process options. The
Options menu appears.
3 Select a restore process option:
- Press R to boot from the hard drive recovery partition
or CD. If no recovery partition is found, go to Step 4.
- Press F to format the hard drive and perform a full system
recovery, then go to Step 5.
4 Click a system restore option. For more information, see
"Restoration options" on page 5.
- Non-Destructive System Restore (Recommended)
- Full System Restore (Destructive)
- Full System Restore (with Backup) (Advanced Option)
5 Follow the on-screen instructions to complete the system
software restoration process.
Oct 29, 2013 | eMachines ET183105 PC Desktop
T2042 emachines audio problems
It's easy to fix this problem.
Stop using the audio chipset on the motherboard, and install a Sound Card.
They are economical, and will surpass the audio quality of that eMachines motherboard, by a mile.
The eMachines T2042 Desktop PC, uses one of these TriGem Imperial motherboards,
Scrolling down you can see the audio is AC'97.
Not worth writing home to Mom about.
The Sound Card you obtain will go into one of those long white PCI slots.
(There are 3)
Any available PCI slot that is open, with no adapter card in it.
Here is but one example of a sound card that will work,
Need guidance in installing? Post in a Comment.
[ Remember to follow Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out, (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE working on your computer.
Computer on a table, computer Unplugged from power, computer case open.
TOUCH an unpainted surface of the metal frame, of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be
SURE to Touch the metal frame again upon your return ]
May 20, 2012 | E-Machines T2042 PC Desktop
How do i reboot emachines
Hi! Welcome to
  • Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.Press F1 when the black screen appears; you will enter the setup configuration mode. You will be presented with a menu.Select Restore Factory Defaults. Your computer will do all the work for you. As with the CD, this process may take several hours.
  • Read more: How to Reboot a Computer Back to Factory Settings '
    Hope this resolution fix the problem on your computer.Thanks for contacting Fixya. God bless. Bye for now.
    Jul 17, 2011 | eMachines Computers & Internet
    How to restore to factory settings
  • Use a memory device such as a rewritable DVD or external hard drive to back up the data you need to save from your eMachines computer. Any data that isn't saved to an external source will be erased when the computer is restored to factory settings.
  • Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner. Do not disconnect the keyboard and mouse. Bring up the "Start" menu and choose "All Programs."
  • Navigate to "eMachines" and then "eMachines Recovery Management." Click the tab labeled "Restore," which is located at the top of the window.
  • Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and then click "OK." Click "Restore System to Factory Default."
  • Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process.
  • Select "Finish" and wait for the eMachines computer to restart. Use the series of installation prompts that appears on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
  • Mar 10, 2011 | E-Machines (T2958) PC Desktop
    I was trying to create the Recovery Management disk but everytime I try to burn the CD it keeps ejecting. I would really like it if you could provide some help. I recently bought this E-Machine computer...
    Welcome to Fixya
    Please see procedure below on how to create recovery disk. Let me know if smae thing will happen.
  • 1
    Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
  • 2
    Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
  • 3
    Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
  • 4
    Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
  • 5
    Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
  • 6
    Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
  • 7
    Set up Windows Vista with your own personal settings.
  • Thank you for using Fixya!
    Dec 04, 2010 | E-Machines emachines (emachinees) CD-ROM...
    What is the best replacement for my T2042 computer.
    It all depends on what you are looking for. If you are looking for a Gaming desktop then I'd recommend Alienware If your looking for producing and editing videos I'd recommend an HP or Sony possibly Mac. For an all around PC go for a Gateway, Acer, eMachine or any other lower branded computer.
    Apr 26, 2010 | E-Machines T2042 PC Desktop
    I had to restore my emachine to factory settings
    Open "My Computer".
    Insert a "data" CD, and hold the LEFT-SHIFT key down for a minute.
    Watch the icon for the CD-drive change from the "standard" icon to something specific to the data CD.
    Right-mouse-click on the CD's icon, and choose "Explore",
    to open Windows Explorer to view the "data" files on the CD-disk.
    Dec 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
    Emachine T1220 with only one restore cd...what else can I do?
    1 Solution for "When ever i plug my eMachine into my dj system through a usb sound card it hum
    Apr 17, 2009 | E-Machines eMachines Desktop PC
    Factory setting restore
    If you have a Cd Rom called a Recovery Disk that usually comes with the computer. You can reformat the computer to it's original configurations. You will lose all data. It will be as if you took it right out of the box. Or on some computers you can do a Recovery only withour reformatting the PC. you will have to reinstall all updates , programs, etc. you turn off the computer and install the disc then you restart the computer. The disk will give you the option to Recover Only or Recover and Format.
    Dec 13, 2008 | E-Machines T2042 PC Desktop
    E-Machines eMachines Desktop PC Logo
    365 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
