Question about GPS
My GPS system freezes when I try to use it, someone told me that I need to update the sd card, it's that trut? how can I do that?
    Champion:
  • 240 Answers
You should also first check the internal clock battry insid the unit.
Posted on Jan 09, 2009
Navigation map do not show up, next turn etc. Also show message "no map info".
My problem was cured by reformatting the Mini SD card that holds the map data. I had the same problem this week with my Garmin Nuvi 265. After doing an update I received the "No Data Available" message when trying to use my GPS. After trying three days of so-called fixes I remembered that, at least in my case, the map is stored on a Mini SD card. I pulled the card from my Nuvi and popped it into the computer to see what's on there. There are 4 or 5 files associated with the map. I deleted the files and reformated the Mini SD card using the FAT32 setting. I reinistalled the card into my GPS. Prior to connecting the GPS to my PC, I uploaded the latest version of Garmin Express. Once that was loaded I reconnected the GPS and had to re-register the unit. Once that was done the software told me that there was a new update. I ran the update. Lo and behold . . . after about 25 minutes the map was successfully loaded to my Nuvi and it was working as it should.
Mar 20, 2016 | Garmin nuvi 50 Travel Assistant
Will not let me enter an address.....shows NO MAP DATA AVAILABLE?????
update failed or was corrupt or memory failed or wiped just reconnect to pc an let it update again
May 09, 2015 | Garmin nuvi 1100LM 3.5" GPS w/ Lifetime...
Can not put an address in garmin nuvi
Try running an update with Garmin Express, let it sit for 30 Min after it says it is done, then check again
otherwise you may have jsut installed a smaller region ,... again Garmin express could help.
Aug 04, 2014 | Garmin nuvi GPS
AVIC-F700BT FIRMWARE ERROR CODE
Download frsh firmware from manufacturer, yours may be corrupt and use a NEW sd card, they do develop faults every now and then
Feb 18, 2014 | Pioneer AVIC-F700BT Car GPS Receiver
My gsp only has a sd card no usb slot so how do i transfer the update to my gps Thanks
Depending on the type of GPS you have, you have a few options...
If the update instructs you to put the update files on the SD card, you need a means for your computer to access the SD card. This can be done by using an USB SD card reader, which can be picked up at your local electronics, digital photography store or online.
If you have another device that allows the transfer of data between a computer and the device (and it uses SD cards), you can put the SD card for you GPS into your other device, connect it to the computer through USB, and transfer the update files. For example, if your digital camera uses an SD card, you could put the GPS SD card into the camera, and then connect the camera to the computer.
Make sure you're updating correctly - sometimes the update is a file you run on your PC that in turn transfers files through a different means onto the GPS. Read the manual for your GPS for more information regarding transferring files onto the GPS and updating.
Mar 12, 2011 | GPS
Screen defaulted to Win CE
well, I had a similar problem once, I managed to get the unit to relaod the map data using my repair dvd but I cannot guarantee this will work in your case. if your unit still has the basic operating system intact, you shoudl be able to boot it with the firmware update in the SD card and it will load, however, someone else told me they were not able to do this becasue the unit would never try to boot from the SD card. it was basically a brick.
One solution is to visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
The other solution was to send it to Fine Digital but they closed their doors in the US so they no longer support us customers. Because of this I made a DVD with map data I purchased from them before they closed and I added much better instructions; this DVD updates the firmware in the unit and loads the last map data issued to the SD card. you would need a PC with a DVD drive and SD card reader to use it. you can find these DVDs on ebay for $18 which basically covers my costs only.
Nov 19, 2008 | Fine Digital FineDrive 400 GPS Receiver
Finedrive 350 system/maps
The CD has everything. You can copy the maps and and the OPSYS to the SD card from the CD. As I have told others, though, the mapset is from 2005 and the man at the factory told me they do not intend to produce an update to the mapset.
Also, the 350 was not made by Fine Tech. It was made by Navtour. In fact, the Navtour 147 is the same electronics in a different package. You can download the mapset at:
http://www.navtour.com/
Jul 26, 2008 | Fine Digital FineDrive 350 GPS Receiver
Trying to start the GPS without the SD card
Try asking someone else, have you tried updateing the firmware on the gps?
Jul 15, 2008 | GPS
Destinator is not a valid Windows CE application
gps will not load said destinator.exe "destinator is not a valid windows CE application unit freezes up will not operate , no menu no nothing unit has a sd card could card be blank if so how can I get it reprogramed?...
Oct 27, 2007 | InVion GPS-7v1 GPS Receiver
GPS Logo
41 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
