Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Blinking green light on Mitsubishi 65513
I heard you had a fix solution with pics and all for the flashing green light on the Mitsubishi 65513? Could you email those to me? Thanks sooo much!
ryan@rltphotography.com
    Sergeant:
  • 233 Answers
Instructions sent. Please remember to rate this answer!
Posted on Jan 14, 2009
BLINKING GREEN LIGHT AND WILL NOT POWER UP.
The capacitors vent causing them not to work anymore. There are 4 of them on the dm board check to see if the tops are buldging.
Aug 30, 2009 | Mitsubishi WS-65513 65" Rear Projection...
GREEN FLASHING LIGHT MITSUBISHI WS-65513
On the front of the tv there is a small hole with a push button in it. Take a toothpick and push the button until the light stops blinking. This should reset your tv.....Joe
Dec 21, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi 65513 Blinking Green Light
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Aug 25, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 green blinking light
Good Day, nixonam;
Jul 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi TV WS-65713
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-65513 green blinking light
I will send that info to you shortly. Good Luck
Apr 12, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65 in Perpetual Blinking Problem:
Replace four 1000mf/25v caps on DM module.....pix's at...
www.Chris@ChrisAndNat.com..................T.
Nov 25, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
192 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
