Spark plug gap champion rcj6y (825)
SOURCE: I have a 25cc Craftsman Blower/Vac
hi
if you have compression and spark(a blue one) try priming the engine,put some gas in the sparkplug hole and start the engine.if it fires only the gas you putted inside there is a delivery problem to find and fix(carburator and hoses.
bye
SOURCE: I have a Craftsman 205mph 25cc blower that I cant keep running?
Check your compression. Usually around 100 - 120psi. Those blowers are only rated for 50hrs of use. Sounds like rings are bad.New set of rings are about 4 bucks.
SOURCE: I received an answer for a 25cc gas trimmer,
The routing of the fuel lines is the same. If you have 3 lines, that means the primer bulb is not directly mounted to the carb, rather it is connected to the carb with hoses.
Line 1. Comes from the fuel filter in the tank (smaller diameter hose) directly to the inlet port on the carb. This is the port that is opposite the diaphragm on the carb. Diaphragm is held on with 2 or 4 screws through a chrome plate. Make sure to leave enough hose so the fuel filter will fall to the lowest point of the tank when it is being used.
Line 2. Goes from the other port on the carb to the short side of the primer assembly.
Line 3. Goes from the longer port of the primer assembly and returns to the tank. Sometimes this line will have a simple coupler on the inside of the tank, but it is optional and its only function is to keep the line from slipping out. If yours does not have this coupler, just leave an inch or two of line in the tank.
*If both ports on the primer are the same length, you can test to see which is pushing air out...that's where line 3 goes.
SOURCE: I need the spark plug gap for a Craftsman Leaf
First, I would like to give you a copy of your online owner's manual:
http://www.managemylife.com/mmh/owner_manuals/15531/CRAFTSMAN-Blower-Gas-L0803240?brand_name_search=+358.794741+
The gap is NOT mentioned in the maintenance section. The normal setting for a machine of this type is a gap of .030"
