Question about Hotpoint First Edition WMA20 Front Load Washer
Hotpoint wm63p washing machinre.
Does anybody know the torque setting for the bolts that hold the bottom weight on hotpoint wm63p washing macine.
    Sergeant:
  • 236 Answers
I replace these weights regularly and tighten them up as tight as i can get them (and i am a big chap) so as tight as you can get them with a ratchet and socket.
Posted on Jun 06, 2007
I got the strap of my swimsuit stuck under the agitator of my Hotpoint washing machine. I removed the top layer of the agitator, but don't know how to get under the part beneath it.
With the first part of the agitator off you now have to remove another cap off the top of what you now see. Under that will be a bolt that holds the whole bottom of the agitator on.
Feb 28, 2015 | Hotpoint Washing Machines
Need to change the drum bearings on a hotpoint wm63p anyone done a video showing how to do it?
If the motor bearings need replaced, you're better off just replacing the whole motor. Save yourself time.
May 21, 2012 | Hotpoint Washing Machines
I have bought a new electric motor for my Hotpoint WM63P washing machine but the old seven pin connector has different locator guides to the new one. any ideas
Your best bet is to refer back to the spare parts shop where you bought the motor. Maybe they supplied the wrong one.....or..there may be an adaptor if the part is compatable...Good luck.....Nomess
Apr 19, 2010 | Washing Machines
Macine holding water and making strange noise
Remove lower rear cover on washer, remove large black hose on bottom of drum, and check the filter inside hose, also remove hose onto pump, and check the pump.
Please rate my solution.
Thanks.
Nov 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Very Loud banging on washing machine spin cycle
Ah,,,,Sounds like drum bearings havee gone the circles iassume is oil from the bearing it will be very noisy on spinen and a lot of play on drum ..quite a big repair..hope you get on ok
Sep 30, 2009 | Washing Machines
Can't find filter on hotpoint wm63p
Remove lower rear panel of washer, locate and remove the large black hose fastened to bottom of tub, you will find the plastic filter inside the hose, remove and clean.
Please leave a rating for my fixya solution.
Thankyou.
Feb 04, 2009 | Hotpoint First Edition WMA20 Front Load...
HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Feb 04, 2008 | Hotpoint Washing Machines
Hotpoint washing machine outer tub moulding
The only way to resolve is to replace the outer tub, no other permanent sollution, what hotpoint mean is that you would not have to replace whole outer drum only the front half.
Oct 11, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
NOT WORKING FDW20p What does it mean
Hold the start key down and it should re-set . Please Rate This ! Thanx!!
Apr 08, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint First Edition WMA20 Front Load Washer Logo
157 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
