Question about Samsung LN52A550 LCD TV
Fried Cable Box and TV not working
Purchased new TV (52") connected to cable box, plugged in, heard pop, could smell burning from cable box. Immediately unplugged all. Now TV not working, no sound, no picture, cable box dead and fried. Help
  • sleeknight Jan 09, 2009
    thanks, yes I already have called cable co and Samsung, but man I just received new tv yesterday, all this happened in one day. can you believe it.
    Sniper:
  • 59 Answers
Hi first call you cable company and let them that your cable box cought firer then call samsung cause you have a year if anything happens just know that you may have to pay for repairs
Posted on Jan 09, 2009
  • tra-voin green
    tra-voin green Jan 10, 2009
    im glad that you got a new tv and i hope you enjoy
My HDTV went out in a lightening storm. What could it be?
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
Aug 03, 2015 | Proscan Televison & Video
My cable channels dont work only 52 53 &54 series Lxi Tv
Try connection with a cable box that uses the audio/video output jacks and connect to a similar input on rear of set---you may have a bad tuner in the set and going via the AV jacks from a box to the set will bypass that.
Jun 10, 2012 | Televison & Video
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
Toshiba 52 inch TV turns on then blacks out.
Unplug the power to the TV and HD cable box, wait 5 min. Plug TV and HD cable box back in.Everything is working like new. Go figure.
Sep 29, 2009 | Toshiba Televison & Video
How do I connect my cable box with an HDMI cable? I can see where the cable connects, but which input do I choose on the device menu?
It is up to you use the HDMI input so you can select it from your remote, notice one may be an output but the cable box hdmi device will plug into the box and the other end plugs into the hdmi cable connector. then select from your remote or your tv that hdmi connection to recieve signal, and set the remote to work with the TV and the Cable box, if you need more help post here and if this was helpful please rate.
Jul 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Go video model dv-241 hook up to make vhs to work
There are a fews ways of accomplishing this.
It sounds like you may reversed your cable connections. Lets try these steps.
On the back of your cable box and your Go video VCR/DVD there are two coxial connections an (OUT) and an (IN):
Step 1. Connect the coxial cable from Comcast to the (IN) connection on the back of the cable box.
Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the cable box.
Step 3. Connect the other end to the (IN) connection on the back of your GO Video box..
Step 4. Connect one end of another spare coxial cable to the (OUT) connection on the back of your Go Video Box.
Step 5. Connect the other end of the Coxial cable to the back of your TV.
I hope that you find this solution helpful.
Feb 10, 2009 | GoVideo Go Video DVD/VCR Combo
Power Surge at Home
This time it came in on the cable, the clue was the cable box also blew. So if you had a cable surge supression device...for HDTV, I think you would have survived the second surge.
I do have the technology. It is a F-connector type and will handle HDTV signal.
Nov 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Has anyone heard of something like this where the cable box/service is causing popping sounds? yes & it is common problem. And is this something I should be concerned about causing damage to the TV's speakers? not at all. The Sony tech-support representative (over the phone) diagnosed it further to a problem not with the TV but with the cable box/service because there were no popping sounds when I played a DVD on my Playstation 2 that is attached to the TV. they are right that your problem is not due to tv. it is due to cable box/service? yes but not defective it reqires to change the way you have connected tv to cable.please call tech to get it connected in such a way so that you do not get popping sound when you you put off cable box.
Sep 23, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Samsung LN52A550 LCD TV Logo
183 people viewed this question
Henry  Thomas
Henry Thomas
