Question about Harman Kardon AVR 55 Receiver
Harman Kardon AVR35
On switching on the receiver i get a flashing message that says "PROTECT". and nothing works, of course.
    Problem Solver:
  • 6 Answers
Check that your speaker wires are connected properly, and none of the wires are touching. if this dosent work hold the sur mode and tune mode at the same time with the unit off(in stand by mode) and this will reset the receiver
Posted on Aug 07, 2007
I have a Harman kardon 1700Avr that is stuck in protect mode, Is there anyway to bypass or reset it? Thanks....
It's in the protect mode because of a component failure inside. It needs to be repaired to get out of the protect mode.
Dec 31, 2015 | Harman Kardon Audio Players & Recorders
Why is it in standby mode only?
Harman Kardon is in STBY mode because its in protect mode
it will not start until u fix the problem
so, what is the model number for your Harman Kardon .!
Dec 28, 2015 | Harman Kardon Audio Players & Recorders
Protect mode
thank you for the advise. i have the harmon kardon avr 3600 and was worried that i destroyed it. i will take it to a shop and get it fixed since it is a great receiver.
Jan 25, 2013 | Harman Kardon AVR 3600
Remote control stopped working.
Hi forlillis,
1. Make sure there are fresh batteries in the remote, and they are installed correctly.
2. Make sure the area between the remote control and receiver is not blocked by some object,
and the distance is no more than 15 feet at an angle no greater than 30 degrees from the
front of the receiver.
3. Make sure strong lighting is not directed towards the IR sensor of the receiver.
4. Press each button on the remote and verify proper operation.
If these steps are taken and remote control still does not function properly
5. This step discharges the capacitor and resets the remote control. (You do not need to point
the remote control at the receiver or even have the receiver turned on.)
A: AVR35  Press the TV and the M4 buttons at the same time and hold for 12 seconds.
To Test: Make sure your AVR35 is ON, press each button on the remote and verify
proper operation of your receiver.
Let me know how it went.
Aug 05, 2010 | Harman Kardon AVR 35 Receiver
Will not turn on. Message Protect
audi amplifier IC,s burned need to replace them
Jun 05, 2010 | Harman Kardon HK 3480 Receiver
Ipod to harman/kardon
Using a headphone to RCA adaptor plug the headphone jack into the headphone connector of the Ipod. Then plug the RCA jacks into any available Analogue input on the receiver. Increase the volume on the Ipod to 80% then adjust the receiver's volume according.
Or get a dock that will allow remote control and charging, such as Roth, DLO or Wadia.
Dec 19, 2009 | Harman Kardon AVR 35 Receiver
No audio from TV on Harmon Kardon AVR35 Receiver
I am attaching some pictures that will show a couple of wiring schemes based on the type of home theater you have. If you have questions with the set up of your HK receiver, please reply with those questions prior to rating your help.
May 05, 2009 | Harman Kardon AVR 35 Receiver
Harmon Kardon AVR300.**protect** blinks when powered on.Took cover off no obvious problem.Disconnected EVERYTHING from back panel,still blinks **PROTECT**.
The protect message means that the outputs are shorted. This is a fairly common problem that can easily be fixed by any shop that handles audio gear. Expect a parts cost in the $20-$40 range.
Mar 16, 2009 | Harman Kardon AVR 300 Receiver
Amplifier/receiver switches off systematically after a few second of use
Sounds like a bad output channel is causing it to go into protect mode. Time to see a repair tech.
May 01, 2007 | Harman Kardon HK 3480 Receiver
Harman Kardon AVR 55 Receiver Logo
870 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
