Question about Optics
Latitude adjustment does not hold
No matter how hard I try to tighten the latitude adjustment joint, it does not hold. the telescope simply tilts forward until the weight has gone as far as it will go.
    Problem Solver:
  • 7 Answers
There are 2 lock down bolts for the latitude adjustment, On my Meade I just witched the front one and the back one around. You will see one of them is longer than the other. This is for the switching depending on which side of the equator you live on.
Posted on Jan 20, 2009
  • 3,186 Answers
Take the bolt out and go to a hardware store and buy one just like it-- except a little bit longer.
Posted on Jan 11, 2009
Telescopic steering wheel wont tilt
Telescopic steering wheel stopped moving - MBWorld.org Forums
mbworld.org/.../225749-telescopic-steering-wheel-stopped-moving.html
Jan 9, 2008 - Telescopic steering wheel stopped moving ... If it won't move at all, and you don't even hear a motor, it could be a fuse; check your fuse diagram ... Steering wheel adjustment motor gone bad?
Jan 28, 2008
HOW TO: Fix power steering column that will not move up and ...
Jul 12, 2007
More results from mbworld.org
Fixing the Power Steering Wheel of a Lexus LS400 - YouTube
? 2:15
https://www.youtube.com/watch?v=NP8YmnGRXWU
Jan 4, 2012 - Uploaded by AutoTech USA
If your power steering wheel is no longer working; moving up and down, back and forth, and when you attempt ...
telescopic and tilt steering not working - Cadillac Forums
Dec 01, 2015 | Cars & Trucks
How to change cv joints
I would replace the complete axle assembly,
it would be cheaper and come with a warranty.
Instructions
  1. Remove the CV Joint
    • Remove the boot straps from the CV joint using a standard screwdriver or a pair of diagonal cutting pliers.
    • Slide the boot back over the interconnecting shaft.
    • Get Chevrolet Info at InsideLine Free News, Videos, Photos & More!
      Detach the stop ring at the base of the CV joint assembly using a pair of snap ring pliers.
    • Pull the CV joint assembly from the interconnecting shaft to force the snap ring at the top of the shaft through the CV joint assembly.
    • Tilt the inner cage (the cage holding the balls in place inside the housing) in different angles to remove the six balls. Use your thumb or a hammer and a wooden dowel, if necessary.
    • Tilt the inner cage enough to remove it from its housing.
    • Rotate the race inside the cage--the part that holds the balls against the inner cage--and remove the race from the cage.
      Replace the CV Joint
      • Apply a thick coat of grease to the new CV joint race using special high temperature/high pressure grease (see Tips below).
      • Install the race inside the new cage. Then install the cage/race assembly inside the CV joint housing.
      • Tilt the cage at different angles and fit the new balls in place.
      • Slide a new CV joint rubber boot over the interconnecting shaft.
      • Install a new snap and stop ring on the interconnecting shaft.
      • Push the interconnecting shaft through the CV joint assembly to force the snap ring through the assembly.
      • Apply a thick coat of CV joint grease to all moving parts of the assembly.
      • Apply a coat of CV joint grease to the inside of the rubber boot. Then slide the boot over the CV joint assembly.
      • Install the boot straps at each end of the boot, and tighten the straps using a clamp tool or screwdriver, depending on the type of clamp.
Mar 22, 2012 | 1997 Chevrolet Cavalier
My Harding Deep Space Hunter 10 will not sit still. It is constantly tilting up with the slightest touch or tap. Any thoughts?
I have never seen one of these--
can you NOT tighten up the Altitude knob tension by adding some teflon washers or felt washers?
Jan 28, 2011 | Hardin Optical Deep Space Hunter 10...
How to tighten 1989 steering column?
There is a u-joint inside the steering column if you have tilt wheel. Which I don't think that I have ever seen a steering column get loose if there is not tilt wheel. If there is not tilt wheel then there are two bolts that hold the steering column up against the bottom side of the dash. You will just need to tighten these two bolts. If you do have tilt wheel, then it is going to require taking the steering column out and replacing the u-joint in the steering column.
Dec 16, 2010 | 1989 Buick LeSabre
The mount that gives you pan and tilt is very loose and none of the adjustments doesnt seem to give it any stability.
That's because it is a TASCO telescope, which are only sold in department and toy stores.
Read my tips on my profile page about buying these types and brands of telescopes.
Nov 23, 2010 | Tasco Galaxsee 45-060675 Telescope
Polar alignment with cg5 mount in the tropics
Wait what? You just have to remove the front bracket for the alt screw and you can go lower than 30 degrees.
Feb 21, 2010 | Celestron CG-5 Mount Telescope
Jeep hard lower soft upper doors 1989 vs. 1991
To make this adjustment you have to loosen the 3 bolts that hold the windshield frame to the dash and the bolt that allows for adjustment in the rollbar extensions. This will allow you to push the windshield forward or backward to close the gap. then tighten everything back up!
Mar 01, 2009 | 1989 Jeep Wrangler
Telescopic Steering wheel won't move down - I hear a gear spinning
Open the gear motor on the left hand side of the telelscopic assembly. Take the plate off held by 4 philips screws. Using a 10mm socket, remove the bolt holding the platic gear. Remove plastic gear and insert the reverse way. Over the years, one side of the gears get worn out.
Oct 27, 2008 | 1997 Lexus LS 400
Celestron telescope
The hinge should be to the north. An imaginary line drawn perpendicular from the center of the tilt plate should point to Polaris (the North Star).
Mar 12, 2008 | Celestron NexStar 4 SE Telescope
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
