Question about Sony PlayStation Portable (PSP) Console
When I turn my psp on it doesn't power on and the screen is blank
  • 25 Answers
Something happen inside your psp it might gotten rumbled inside maybe you dropped it so go to a mechanic to fix it
Posted on Jan 10, 2009
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
Fourth times when i off the psp and then turn on back, everything hang and not able to play at all. can anyone teach me how do reboot like the shop pple. they charge me each time and not willing to teach...
First, try holding the power switch for 10 seconds, this does a complete reset of the PSP, but doesn't reset it to factory settings.
If that doesn't work, turn it off the same way as above, but this time, hold SELECT, START, square and triangle as the machine starts up. Keep holding them down until you see the screen light come on, but just a blank black screen. It'll show that screen for a few more seconds, then it should be just like it was when you took it out of the box. You'll go through the initial setup again.
Here's the video I got the information from: http://www.youtube.com/watch?v=MCsFiWO03d0
May 10, 2011 | Sony PlayStation Portable (PSP) Console
When slidding power lever up, it turns green but nothing happens. It's just a blank screen
Probably Your PSP brick. You can take it to sony to fix it. Or pandorized the psps if your psp 1000 or psp 2000 below ta88v3
Aug 31, 2010 | Sony PlayStation Portable (PSP) Console
Locked/Blank PSP Screen
sounds like a classic psp bricking...sort of
Jun 09, 2010 | Sony PlayStation Portable (PSP) Console
Psp green power light on but blank screen
You most likely bricked it from an update. Depending on your psp's model you can diy a solution or your stuck with sending into Sony.
Apr 19, 2010 | Sony PlayStation Portable (PSP) Console
All I get is a blank screen on my 2001 Psp
is a hung psp switch the power slider off then again turn it on ...it should solve ur problem
Feb 09, 2010 | Sony PlayStation Portable (PSP) Console
Psp not turning on
theres several things that go wrong with PSP screens.
1:) the lcd backlight has gone.
2:) the lcd screen has gone.
3:) The console has had an unsucsessful firmware update.
And is failing to Boot.
Mike @ Compurepair.
Apr 02, 2008 | Sony PlayStation Portable (PSP) Console
Sony psp
if u have nero7 kit u have an option for converting to psp format try it out
Mar 22, 2008 | Sony PlayStation Portable (PSP) Console
Psp problem
remove the battery from the psp and put back in again as sometimes the power light freezes on, but isnt actually powering the psp.
Sep 07, 2007 | Sony PlayStation Portable (PSP) Console
Psp turns on but there is a blank screen
it probably froze try and remove battery. if that dont work turn it on and wait a second then hold the power switch in the off position but do not let go until it turns off that should completey restart it.
Jul 14, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
