Question about Stoves Broan 40000 Series Hood - 30" Hood (ABE403001)
The swich on the stove fan has stopped working
It is a Broan 42.000-K fan, date code 00J, 120 Volts.
  • ronaldjudi Mar 08, 2009
    Had the fan on and then it was off. It is a QT 2000, serial number 10031 1456471. We remodeled the kitchen 4 years ago and the fan was installed then.
    Judi
Hi
I called the company, they had the spare part and is shipping it shortly. I have some friends who will be able to help me install it.
Thank you
Anne
Posted on Jan 12, 2009
Frigidaire stove model CFEF372EC3 Ser #NF60720192
Things to check : Thermostat, heating element and the circuit breaker for the stove at the power panel. If the stove has lights and the clock works, there is a 100 % chance the circuit breaker is at fault. There are 2 breakers with joined trip handles. One of those breakers has tripped without tripping the other which stops 20 volts but not 120 volts that the clock and light run off of. You can use a multimeter to check the element for continuity. If there is continuity then check for the presence of voltage at the element terminals. None indicates a bad thermostat.
Nov 02, 2015 | Frigidaire Kitchen Ranges
I installed a broan 112 kick board heater. I followed the manf instructions for changinging from 240 to 120. The fan runs when powered up but no heat. Do you think I blew the thermal fuse?
its rare to see a 120 volt baseboard heater.. most are better in efficiency at the 240 volt setting..if you dont have a 220 setup for it.. may want to put one in.. its not that hard..and it will work much better..
Jul 10, 2014 | S99521763 Srv Asm Thermal Fuse F/112
I have a bathroom Broan 504/505 vent fan. This model just stopped working. I have power to the unit but for some reason it wont work. I pulled the fan plug from the fan housing & used an extension...
the motor is prob rated for 120-140 volts if your only getting 110 there is the problem see what the breaker is putting out at the box the light will still work but the motor needs enough amps to start sounds like a voltage drop issue
Aug 06, 2011 | Heating & Cooling
My Simpson Esprit oven is not supplying power to the heating element. The fan and light run normally but no heat. Do these ovens have an internal fuse for the element? I checked the element for continuity...
Check to make sure that there is 120 volts from each oven wire seperately. Together they should be putting 240 volts to the oven unit. Do you have a fuse box instead of breakers in your home? It could be that one of the two fuses is bad. The oven needs two legs of 120 volts to heat up. Usually there is no internal fuse on a stove, just on clothes dryers.
Jun 10, 2010 | Kitchen Ranges
My heating in my maytag stove burnt out will that stop the glass top heating units from heating up
No. Sounds more like a power problem. Check your circuit breakers for the stove. You shoud be getting 240 volts to the stove. If you are only getting 120 volts the clock and lights will still work but no heating.
Mar 02, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Fes330 roper stove power to stove ...ok no fault codes on display normal "stove on" lites....ok normal appearance except no heat from 4 eyes and oven below
you have no heat at all? K, pull stove out and check how many volts you have should be 240. Your elements work off 240 if you only have 120 coming to stove the lights will work jujst not your heat. You should have a double pole 40amp breaker If you only have 120 change the breaker
Aug 31, 2009 | Roper FES330 Electric Kitchen Range
Nutone range hood fan motor quit
You can remove it and bench test it by applying 120 volts to the fan leads. Do you know how to do this -- it can be dangerous if not done properly.
You can also use a voltmeter to measure resistance and check continuity of the motor coils.
May 07, 2009 | Broan-NuTone Intermediate Whispaire ...
Electric stove lights work but nothing else
sounds like the range is not getting 240 volts. When it only gets 120 volts lights will work but no heating element will. You need a volt meter and make sure that you have 240 volts across the black and red wires. From black to white and from red to white you should have 120. If you find you have a voltage problem you need to check your fuse box. you could have a fuse out or a circuit breaker can also be bad
Jul 24, 2007 | Whirlpool RF302 Electric Kitchen Range
Kitchen Ranges Logo
241 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
marley mcelhinney
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
