Question about Soundmatters MAINstage Theater System
Remote code for soundmatters
I need remote code for soundmatters main stage
  • 1 more comment
  • bcasey66 Feb 10, 2009
    The remote for my MAINstage is worn out (volume buttons barely work), and I would like to get a code for my DirecTV remote, or even possibly a replacement remote.
    The remote for my MAINstage is worn out (volume buttons barely work), and I would like to get a code for my DirecTV remote, or even a replacement MAINstage remote.
    Thanks,
  • flood69 Feb 16, 2009
    same issue. i need a 3 digit remote code for a soundmatters mainstageHD
Hi I need the Big End Torque settings for a Nissan 1400 Champ bakkie
Mains Stage 1 83nm , Mains Stage 2 167nm Big ends Stage 1 29nm Big ends Stage 2 45 - 60 degrees
Jun 06, 2016 | Nissan 1400 Cars & Trucks
Tip
Dish Network Stereo Receiver Remote Codes
This is the From the Dish Network website. http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml You can also call them for information on your set-up at : New customers call: 1.888.825.2557. Current customers call: 1-888-686-2388. CODE Aiwa Amplifiers 636, 641, 656, 687, 718, 720, 774, 775, 726 Bose Amplifiers 761 Carver Amplifiers 653 Citizen Amplifiers 709 Curtis Mathes Amplifiers 734 Denon Amplifiers 647, 674, 757, 758, 759, 760, 762 Fisher Amplifiers 653, 741 GE Amplifiers 711 Goldstar Amplifiers 677, 69 Harmon / Kardon Amplifiers 640, 672, 751 Hitachi Amplifiers 717, 754 JBL Amplifiers 640 JVC Amplifiers 637, 683, 703, 725 Kenwood Amplifiers 649, 676, 691, 726, 728, 745 Luxman Amplifiers 752 Magnavox Amplifiers 654, 705, 740 Marantz Amplifiers 651, 740, 742, 743, 764 NAD Amplifiers 739 Nakamichi Amplifiers 671, 748, 750 NEC Amplifiers 716, 739 Onkyo Amplifiers 642, 660, 662, 678 Optimus Amplifiers 648, 664, 734, 744, 749 Panasonic Amplifiers 643, 644, 652, 742, 746 Pioneer Amplifiers 658, 667, 668, 679, 702, 734 Proton Amplifiers 654, 705 Quasar Amplifiers 652, 742, 746 Radio Shack Amplifiers 744 RCA Amplifiers 635, 638, 704, 727 Sansui Amplifiers 753 Sanyo Amplifiers 741 Sharp Amplifiers 712, 713, 714, 715, 749 Sherwood Amplifiers 646, 670, 736, 738, 744 Sony Amplifiers 639, 645, 650, 687, 728, 728, 730 Soundmatters Amplifiers 763 Teac Amplifiers 684, 737 Technics Amplifiers 643, 644, 652, 742, 746 Toshiba Amplifiers 710 Yamaha Amplifiers 663, 730, 731, 732, 733, 745, 747
on Jun 06, 2009 | Toshiba XB1507 Receiver
NEED TO KNOW WHAT ARE THE TORQUE SPEC N A F250 2001 GAS ENINGE FOR THE ROD BEARINGS AND MAINS BEARINGS 5.4
I hope this helps you. WF
  1. Install the main bearing cap bolts and the cross-mounted main bearing cap bolts.
  1. Tighten all of the main bearing cap bolts in two stages.
    Stage 1: Tighten the vertical fasteners 1 through 10 to 37-43 Nm (27-32 lb/ft). Rotate fasteners 1 through 10, 85-95 degrees.
    Stage 2: Tighten the cross-mounted fasteners 11 through 20 to 27-33 Nm (20-24 lb/ft). Rotate fasteners 11 through 20, 85-95 degrees.
Tighten the connecting rod bolts in two stages, using the sequence shown.
Stage 1: 40-45 Nm (30-33 lb/ft)
Stage 2: Rotate 90-120 degrees
Aug 21, 2010 | 2001 Ford F250 Super Duty Super Cab
I had a lightning strike last night. There is a green blinking light on the front of the television but does not turn on with the remote or the buttons on the side of the tv. Does anyone know what the...
If you rre lucky to get away with a low cost repair , pleae open and ccheck for failure of the surrge protector / fuse in the mains front end. use a meter to check for shorts in mains circcuit. If +B is fine with all votages then your set has a fault into the main cicuitry, you will need to systematically probe stage by stage, could be multiple failure if the strike has gone in and maybe costly. Good luck
Jun 30, 2010 | LG 50PC5DC 50 in. Plasma HDTV
I need the torque specs for the main and rod bolt for a 99 escort 2.0l engine
engine tightening torques
Main bearings Renew bolts/nuts No
Main bearings Stage 1 43 Nm
Main bearings Stage 2 85 Nm
Big end bearings Renew bolts/nuts Yes
Big end bearings Stage 1 15 Nm
Big end bearings Stage 2 90°
Jan 21, 2010 | 2004 Ford Focus
Hi, im rebuilting a 88 2.0l 8v and i need the torque mesure for the block and head bolt thx
Eng.code 3A- Cyl.head-stage 1-40Nm,stage 2-60Nm,stage 3-180degrees. Main bearings - stage 1 - 35Nm, stage 2 - 65Nm, Big ends - stage 1 - 30Nm, stage 2 - 90degrees. Flywheel - stage 1- 60Nm, stage 2 90degrees. Eng.code AAD - All torques same as engine 3A. cheers
Dec 01, 2009 | 1988 Audi 80
Need torque settings for big end and main bearing bolts on 1999 KIA Carnival V6 k5 2.5ltr
big end - stage one 18-22 Nm. stage 2 40-50 degrees
main bearings stage 1 20 Nm stage 2 90 degrees
Oct 23, 2009 | Kia Sedona Cars & Trucks
Needing engine bolt torque specifications for a 2006 Ford Five Hundred with 3.0 liter engine. This will need to include rod and mains torque and torque rotation.
stage 1 tighten to 30 ft pounds
stage 2 tighten 90 degrees
stage 3 loosen one full turn
stage 4 tighten to 30 ft pounds
stage 5 tighten 90 degrees
stage 6 tighten 90 degrees
this is per mitchell on demand courtesy of ford specs on the lft and right head.
for some reason there are no torque specs on mitchell for connecting rods and mains.
Sep 15, 2009 | 2006 Ford Five Hundred
Rca universal control
You may not have the correct code. There are sometimes more than one code that will activate certain stages of the TV. I am going to send this web page and you may find a better code that will make the TV work properly in all stages. If this solution doesn't work, you may want to send me the model of the remote control you have and I may be able to look up a better solution. If furture help is needed, you can always email me at wyoed1@aol.com.
click this link on for rca remote information:
RCA Universal Remote Control-Programming Codes
Ed
NC Electronic
Mills, Wyoming
Jan 08, 2008 | RCA Universal Remote Control
Soundmatters MAINstage Theater System Logo
679 people viewed this question
Top Soundmatters Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Soundmatters Audio Player and Recorder Expert? Answer questions, earn points and help others
