Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine dies off once brake/clutch is released
My craftsman riding mower starts fine, but as soon as i let out the brake the engine shuts off.
  • Prestwood Feb 01, 2009
    I have a Transaxle that had a broken Ring Clip in the transmission. I replaced the clip and reassembled. Everything back in place and filled with oil. Wheels run if I hope the belt in but if I use the Clutch/Brake it kills the engine. Not sure how to properly set the brake or if it is even working properly down on the right lower side if the transaxle. Is there a manual that would cover this?
    Thanks, Ron Prestwood
  • Anonymous Mar 22, 2014
    noise when clutch disengaged
    New Friend:
Your answer was perfect, when I located the saftey switch it was not working properly.
Thanks a million, Ron
Posted on Feb 12, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why does engine die when brake released or mower engaged?
The first thing I would check is to make sure the drive belt is not binding somewhere.
May 17, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My craftsman law mower will start but as soon as you let off of the brake it dies
Pull the throttle control out of choke once the engine starts. Otherwise it will stall.
Apr 29, 2012 | Craftsman Garden
My Craftsman 42" 18.5hp lawn tractor will start fine but when I disengage the brake or engage the blades it cuts off. It was recently left out in the rain while I was working, did something short out? It...
there is a safety switch under the seat. to stay running after the brake is released or deck engaged you have to be sitting on the seat or it will die. if this switch is bad it will die as soon as you release the brake.
Aug 25, 2010 | Craftsman Garden
My sears craftsman riding mower will crank just fine, but as soon as I try to either put it in gear and release the clutch to go forward or backward, it shuts off. It also shuts off when I attempt to...
Many folks have found that a defective relay in this mower to be the cause of the "stall when i take my foot off the clutch" issue. The relay is connected to the safety switches which turn the mower off when no one is in the seat, etc.
Aug 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 1994 G4000 craftsman riding lawn mower i got it running but when i let off the pedel the engine shuts off the switch for the brake/clutch is fine and i replaced the selonoid and key start also the...
If electrical ( the motor shuts down like you turned the key off) its likely the rider presence switch ( seat switch).
If the motor is pulled down and dies as if its uncapable of handling the load check the drive system. Remove deck and check drive belt and pulleys. Pull the belt off of a pulley for slack and with the tranny in first and the brake released you should be able to turn the large pulley on top of the tranny easily which should cause the tractor to start to move. If you cant turn the pully there is something wrong in the tranny.
Nov 30, 2009 | Craftsman Garden
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,110 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
