Question about Emerson EWL20D6 Television
Does the Emerson 20S5B have a digital or analog tuner?
I've tried to locate the manual online, but with no success.
  • 240 Answers
It is a digital system, and yes vhs anolog. and it is HD ready.
hope this helps.
Posted on Jan 09, 2009
Does my Emerson LCD TV/DVD combination model LD195EM8 7 have a internal QAM tuner?
The Emerson LD195EM8 7 does not have a QAM tuner. It just has the ATSC (digital OTA) and NTSC (analog OTA and cable) tuners. Emerson TVs are manufactured by Funai. You can find most of their manuals here: . Enter your model number without the 7 to find the download link; the direct link is hidden in the Java script. Sears Parts Direct also has the manual. The direct link to the LD195EM8 manual is .
I wish that I had better news for you. I hope this helps.
Aug 17, 2015 | Emerson Televison & Video
No. It's tuner is analog. However, your cable company may still broadcast some analog channels. But if that's the case, your TV will pick up the same channels.
Feb 01, 2014 | Emerson EWD2204 DVD Player/VCR
Can I records from a LC195EMX TV
No you can't output the video signal from the LC195EMX's tuner to another device. It only has video inputs to obtain the signal from a DVD or Blu-ray player, for example. There are audio outputs to use with a sound system or headphones. Thus you could record the audio track, if you desired.
The manual for the LC195EMX is available from Emerson: . You will need some sort of a set top box to record to a DVD/VCR recorder with either an analog tuner or no tuner. (OTA digital to analog converters connect easily to DVD recorders. For best signal, use a switch to feed the signal to the recorder, instead the TV. Splitters can be used to feed both at the same time. However, the signal loss could make either or both devices unwatchable with the digital OTA signal. Amplified splitters can reduce this issue; however, I've had the amplifier fail on several occasions. Then the amplifier blocks all of the signal or blocks select channel frequencies.)
I hope this helps.
Sep 27, 2013 | Emerson LC195EMX 19 in. TV
Emerson EWF2006 TV access code
if your tv doesnt have a digital tuner, you cant, unless you have a digital to analog tuner converter (can be purchased in walmart, or other stores that carry tv s, electronics) you tune your tv to 3 or 4, use the converter box to scan for channels, and for changing channels instead of your tv tuner
Mar 21, 2013 | Emerson EWF2004 20" TV
Do these TVs have tuners that allow then to pick up and view digital broadcast stations without being hooked to a cabelo or satelite system?
The Emerson LD195EM8 has both an NTSC (analog) and an ATSC (digital) tuner with an RF (coax) connector. So you will be able to watch current OTA TV without a set top box (cable/satellite/converter).
I hope this helps.
(assuming no damage to the tuners or the input jack)
Jun 06, 2011 | Emerson LD195EM8 19 in. LCD TV
Im trying to hook my standard antenna up to my jvc av 56p585. i dont have manual. and i cant get any channels. what do i need to put my tv on to get my basic local channels
This JVC TV has an NTSC (analog) tuner. So it can only receive some of the few remaining low power tv stations that are still using analog transmitters. Depending on your location, you may not have any of these stations within the range of the antenna.
You need an digital-to-analog tuner to get additional channels. Use or to check for stations in your area and the appropriate direction to point that antenna. (You may need an amplifier since digital stations are either sufficient signal for the tuner to use or you get "no signal".)
Please note that the d-t-a tuners that were available with the government coupon cards only handles standard definition signals (480i). The HD tuner digital to analog converters are available at some online sites but cost more.
I hope this helps.
(you can use a tuner in your computer (USB or PCI card), but you will need a converter unless your video card can put out a signal other than RGB. The HDMI port on the TV will not interface directly with a computer.)
Nov 06, 2010 | JVC Televison & Video
Digital Tuner in Emerson EWF2004
Check this link for more info. You tv is not HD capable because it has an analog tuner and not a digital one.
Jan 07, 2009 | Emerson EWF2004 20" TV
Analog or Digital?
This tv is analog, EDTV is only enhanced definition tv ,480p resolution, not the HDTV 1080i or 1080p resolution, the mts/sap tuner has to do with the audio decoder. For example: SAP would allow you to view a station broadcast in english to be heard in spanish. MTS is surround sound broadcast. Thanks
Apr 02, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Emerson EWL20D6 Television Logo
88 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
