How do I make my TV see the DVD output? I have Spirit Broadband TV and a good dvd player. I can.t get the TV to Channel 00.
  • 3 more comments
  • Dick Riesz
    Dick Riesz Jan 09, 2009
    Yes, but which remote? The DVD? The TV? I need the dvd outbput sent to the TV. Do I need to turn off the cable feed?
  • Dick Riesz
    Dick Riesz Jan 10, 2009
    Get me started. i HAVE CABLE tv (sPIRIT bROADBAND tv) AND A GOOD DVD PLAYER. hOW TO MAKE THE dvd OUTPUT APPEAR ON THE tv? sTEP-BY-STEP, PLEASE
  • Dick Riesz
    Need more help
  • Dick Riesz
    Sure, but I don't need a hard-wire solution. An older DISH controller had a button that connected - somehow. But the present one does not have that button.
  • Dick Riesz
  • 818 Answers
    Genius:
  • 1,036 Answers
Sometimes there is a conflict between units, so you may need a "smart" scart adaptor, and only have one unit on at the same time.
Set your TV to do a station scan - and see if it picks it up on autotune.
Posted on Jan 10, 2009
    Genius:
  • 1,239 Answers
Hi
i think you can see av,tv button in your tv remote press av button and it will be activated to dvd mode...and check If your TV has RCA outputs via Yellow, White, and Red Plug the cords from the output of the DVD player to the input of the television.
  • ABHISHEK.C
    ABHISHEK.C Jan 10, 2009
    pull out all the connections you have made [but not the
    speakers and sub]. it is much easier to start from scratch.
    1.a. dvd - sound. all you need is a coax wire from the apex's digital
    coax output [the orange colored one] to the coax digital input on the
    receiver [this one is black, not orange].
    1.b. dvd - video. run a video wire [composite for now, you can swap an
    s-video in later] from the dvd player into the input on the receiver
    labeled dvd/ld.
    2.a. vcr - input. run a/v wires from the vcr's OUTPUT into the INPUT
    labeled vcr/dvr on the receiver.
    2.b. vcr - output. run a/v wires from the vcr's INPUT [or line 1] into
    the OUTPUT labeled vcr/dvr on the receiver.
    3.a. tv. from the receiver's moniter output, run a composite video cable
    into the tv's video input.
    3.b*. tv. if available, run a set of audio wires from the tv's moniter
    out or audio out into the receivers tv/sat audio input
    4. run an rf wire from the vcr to the tv
    now, that is all that has to be hooked up for now. if your tv can use
    s-video, you can run the s-video direct to the tv's s-video input from
    the dvd players s-video output.
    the receiver will not change formats: it will not convert composite to
    s-video, or s-video to composite.
    now on the receiver, setup the coax digital to be on dvd/ld, and on the
    front panel, select dvd/ld, then press the signal select button [at the
    right, by the volume knob] make sure the signal select is digital, not
    analog. in the dvd players setup menu, make sure to turn on the dts
    bitstream, and the audio out to digital/raw [i think it is that, i
    haven't owned an apex in a few months now..]
    if your tv doesn't have a moniter out with fixed audio, or a dedicated
    audio out, you can just use the vcr to tune the channels and get the
    sound through the system from that.
    that should get you going. hope it helps
  • 470 Answers
If you have iDVD and can format a happy menu/chapter selection in iDVD, I might have a solution. 1080i in my experience consistently gums up DVDSP.
We have a DVCPRO HD 1080i60 project, and we had a heck of a time with the interlaced video going to DVD. We landed on this solution - it preserved the aspect ratio, it reduced the interlacing to an acceptable edge and it didn't take too terribly long. But it's a homemade solution and until I hear otherwise, it'll have to do for us. We use it to output cuts for composers, producers, whatnot - for our final output, we'll probably do a big compression from interlaced 1080 to progressive 1080. We have another project shot at DVC PRO HD 720p and it has none of these problems when compressing for DVD.
I output a quicktime using File>Export>Using Quicktime Conversion. I clicked on options next to the Format pull-down menu. From there I hit the Size button under the video heading. Under Dimensions I scrolled down to Custom, then entered 864x486 - this provided us with the best resolution downres-ed from 1080i with the proper aspect ratio built in. (We left the "Preserve aspect ratio using" box unchecked.) I then clicked - and this is important - Deinterlace Source Video. I still looks a little edgy but acceptable. Some have suggested putting a channel blur filter on the sequence at .35 to 1 pixel of blur to help with this - I think it boosts conversion times, so settled for just the deinterlacing checkbox and our image looks a little too soft for that solution.
Our sequence is 15 min. in length, and it takes an hour to make the quicktime. From there it's about 15 minutes in iDVD. It looks good and the resulting quicktime hasn't given us any problems in iDVD.
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 10, 2009
    just check the output channel or maybe you did not complet the formatting on it
    Sergeant:
  • 378 Answers
Connecting your Television, VCR, and DVD Player:
NOTE: Do not connect a DVD Player to a VCR and then to the TV. Copyright protection will prevent the DVD signal from displaying clearly when routed through a VCR (as well as prevent copying of DVD movies to VHS). Connect your components as outlined below.
First, connect the DVD Player as follows:
You will require: audio / visual cables. You may also use an S-Video cable in place of the yellow visual cable if you prefer, and your television has an S-VIDEO input. Connect the AUDIO OUT jacks on the DVD player to the AUDIO IN jack(s) on the rear of the television. Then connect the VIDEO OUT on the DVD player to the VIDEO IN on the television, OR connect the S-VIDEO OUT on the DVD player to the S-VIDEO IN on the television.
Connecting your DVD player in this manner will not affect your cable or antenna connection to your television. Please see Connecting Your Television and VCR for further details on these connections. To use the DVD player, the Input Mode or Channel on your television must be changed. Consult your Owner's Manual for instructions on using your TV and DVD player.
===== if you want to see the diagrams of which point to connect where just click this link and see the diagram and connect in that way in your device and unit
http://www.funai-corp.com/support/setup.aspx?prod=dvd2tv2vcr
thanks.
    Genius:
  • 1,913 Answers
Connect your dvd output to tv s input port.
    Sniper:
  • 62 Answers
If your TV has RCA outputs via Yellow, White, and Red Plug the cords from the output of the DVD player to the input of the television. There should be an input/aux button on your tv remote. Power on your dvd player and hit that input button until you see the DVD on your television screen.
If you have any further issues, let me know.
    Novelist:
  • 151 Answers
Hello, try switching to channels 3 or 4
check these too
you can connect if you have extra inputs on rear of the tv or in front
try using line 1 or line 2 rca connector input the rear of the tv.
switch to the desired line with the remote control
if you use the rear extra inputs with rca cables
yellow video
red sound
white sound
good luck hope this helps
Posted on Jan 09, 2009
  • charlie rodriguez
    charlie rodriguez Jan 10, 2009
    you use your tv remote to switch between the input and tv signal
    then you can control the dvd functions from the dvd remote
  • charlie rodriguez
    charlie rodriguez Jan 14, 2009
    if you have a vcr you can add the dvd to the vcr the incoming broadband tv signal to the vcr and use both combined with a simple vcr player you may solve your issue
    then you can use your vcr remote to switch between them
    this may help,. good luck.
    Master:
  • 416 Answers
You can buy an AV-RF converter (Big Lots 9.99) and connect the output of DVD through AV in on converter which would be connected through Antenna Out to antenna in of TV. Spirit Broadband TV will go trough antenna in of converter. If DVD has S-video out you can buy the converetr with S-video in and connect the dvd through S-video, while having Spirit to be connected through antenna in. Depending on brand of TV you will hav DVD in at 00-05 channels.
Good Luck
  • Grigory Zyryanov Jan 09, 2009
    If TV has AV in ports you can also connect the DVD using AV out DVD to AV in on TV
  • Grigory Zyryanov Jan 10, 2009
    1. Check you TV if it has AV-in port in front or back panel or S-video-in
    the examples are here
    http://www.valley-ent.com/catalog/rca-sv...
    2. If there are no those ports on tv you need to get one similar to shown (Big Lots 9.99)
    3. Connect DVD-AV out or S-video out to TV or corresponding ports of adapter you got
    In case of adapter port TO TV or Antenna OUT goes to Antenna in of TV.
    4. Connect the cable Spirit Broadband TV (from converter box if you have it or from a wall) to Antenna in on TV or Adapter (if you usimg adapter).
    5. Turn DVD and TV on and go to MENU-INPUT SELECTION-CABLE and Check the cahannels for DVD signal (it would be blank blues screeen with DVD BRAND logo on it or something similar).
    6. If you can not find it you need to go MENU-CANNELS-AUTO CHANNEL and TV will find it
    Good Luck
    Top Expert:
  • Televison & ... Master
  • 70,374 Answers
Does the TV have RCA inputs? use them, if u don't have RCA inputs then u will need a RF modulator and the TV set to channel 3 or 4, if u do have RCA video inputs then the TV must be set to auxiliary video in the TV's on screen menu.
  • yadayada
    yadayada Jan 09, 2009
    there may also be a video input selector button on the TV or on the remote.
  • yadayada
    the tv remote is what u must use
    Brigadier General:
  • 5,158 Answers
There should be a setting on the remote for dvd and aux... try each of those
  • Roberta Smith
    Roberta Smith Jan 09, 2009
    when you hooked the dvd to the tv.... did you hook it up directly to the tv ? ... if so you use the tv remote to change to dvd or aux
  • Roberta Smith
    Roberta Smith Jan 10, 2009
    Have you tried turning the dvd on and tuning to either channel 3 or 4 ?
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
My I got sound but no picture on my DVD player
There are three coloured leads on the back of a DVD player if you use composite video - Red is Right channel sound, white is Left channel, yellow is video.
Red from DVD right output to TV right input
White from DVD left output to TV left input
Yellow from DVD video out to TV video in
Sep 03, 2012 | KLH DVD8350 DVD Player
How do I hook my Sanyo DVD/VCR player to my slyvania TV
Wow - lots of info needed about your tv for a good answer there. But I can assume you only have a cable TV hookup on the back of your TV - and dont have a RCA input. So I will go on that. I had an old TV and had just this situation... I used my VCR to interface the DVD player for me.
So I ran the DVD player output to my VCR ( that had the typical RCA cables ) - Vidieo - Right channel- left channel - and then ran the VCR output COAX ( standard cable TV cable ) from my VCR to my old TV. once I selected channel 3 or 4 on my tv, I could see my VCR and my VCR would send me the DVD output, if I set the VCR to do that. Now I could record a DVD onto VHS ( for my personal use only of course ) good luck...
Jan 25, 2012 | Sanyo Televison & Video
How do i hook up a dvd player to my tv if i have cox cable? I dont know what channel to put my tv on. I know there has to be a way to watch a dvd without unhiiking the cable
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
Mar 20, 2011 | Samsung Televison & Video
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
Feb 11, 2009 | RCA F27252GY 27" TV
Hooking up dvd player
Look for any button either on the unit or the remote marked with common stuff like A/V, Input, Source, Aux or Au, Line, TV-VID. or try dialing in Channel 0, or 00, or 1, or Channel Down surf below Channel 2. Alternately, get into the menu and look for stuff concerning Auxiliary inputs.
If all else fails, you can run a DVD's audio and video line-signals THROUGH a VCR. Hookup the VCR to the TV's RF (threaded) connector using standard coaxial cable. Hookup the DVD a/v output lines to the Line-ins of the VCR. Tune the TV to Ch. 3, tune the VCR to Line-in or Auxiliary and press the play or tv/vid button on the VCR to force the DVD signal through on channel 3 onto the TV.
Jan 25, 2009 | Disney 13" TV
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
