Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Disk unreadable message from ffxi
By olddev on Jan 09, 2009
I will get the disk unreadable message that others are having, I read through the solutions that were given, but when i go and try and reinstall it, it wont let me get to the screen with that option. The error message happens before the reinstall menu. Any ideas how to get passed this?
Same Problem
Jan 29, 2009
-   Disk Read Error on FFXI says to re install i am annoyed!-   Guest
Best Solution
posted on Jun 19, 2009
Very Helpful)
mike59034
Rank: Apprentice
Rating: 100%, 1 votes
I just had this problem and I have a solution!!! You must reformat your xbox 360 hard drive. To wipe hard drive go to system settings, than memory and hover over "Hard drive" and hit Y and hit reformat, From there on it will give you directions. Reinstall game and your good to go! The problem is corrupt files thats why it will not start I hope this helps!! It worked for me!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 13, 2009
Helpful)
HydroFoxx
Rank: Apprentice
Rating: 92%, 3 votes
I had this problem.
If your disc is not damaged, then the most likely problem is the FFXI data has been corrupted.
This can happen if you improperly exit FFXI or the POL viewer, such as just turning off the console, or your console freezes.
Since the FFXI data is not displayed on the Memory section in the dashboard, and you cannot load the disc to reinstal from the POL viewer, you must reformat the HDD through the memory section of the dashboard.
Make sure to back up all other game data onto another storage device, as reformatting will delete everything.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Mar 07, 2009
Somewhat Helpful)
johanna_rao
Rank: Master
Rating: 75%, 2 votes
Microsoft Xbox have some common problem like red lights, E74 and Disc Read Error. Microsoft is providing extended warranty for red lights problem, Means you will have to spend some money in order to get this problem repaired from Microsoft also you will have to wait for 3-4 weeks to get your Xbox back. There are many reasons disc read error can occur in your Xbox like your disc might not be clean, laser might also be dirty and many more common problem. I would suggest you to first clean out the disc, you are using. If that don't solve the problem you can also take the help of DIY guide available at Internet. I think you have got good no. of options to get your Xbox repaired, Choice is yours.
Was this helpful?
Yes
No
Solution #4
posted on Jan 11, 2009
Somewhat Helpful)
nozknows
Rank: Master
Rating: 80%, 4 votes
if the disc is scratched that could be the problem. Unfortunately I had this problem right before I got the ring of death.
Was this helpful?
Yes
No
Solution #5
posted on Nov 12, 2009
Not Rated)
Shadow2009
Rank: Apprentice
Rating: 0%, 0 votes
Okay No that ISN'T the problem the Games works fine no scratches at all Brand-new pop it in the console install it and you get to play after a 5hr downloads yes cool, now after you get done playing...You log out black screen freeze up you turn the xbox on try to start FFXI up again NOPE says the disc is unreadable or dirty, and jus for all you ppl who say installing it to the HDD VIA pressing Y button and hitting install NOPE installation of the game is not supported what now? problem isn't solved I'd like to play FFXi on my Xbox 360 so I don't have to play on the PC my GF does Homework on the Fix hasn't been made for a year or so now.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
my xbox is displaying the problem E74 it gave me this site for question with the problem
Answer
I have an x-box that is just under one year old. When it was switched on this week it failed to... (More)
Answer
we turn xbox on and we get nothing on screen,but the console has three flashing red lights(bottom... (More)
Answer
After several minutes of having my xbox 360 turned on the screen goes fuzzy and the system shuts... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
