Question about Freestyle Predator 10 Lap 722 Wrist Watch
Clock Somehow the time got switched to military time and I can't figure out how to get it back to normal. I've had to reset the time whenever it's later than 12 noon each day. How do I get the time set back to normal?
  • Anonymous Jul 22, 2008
    how do i set the time
When you are in t1 mode. All you have to do is press the 10 lap button- black bar at bottom of time display.
Posted on Mar 09, 2008
SOURCE:
My father in law has an old Casio model 548 wrist watch. It's stuck in military time and he wants to reset the time to a 12 hour option and move into daylight savings time. Can you help?
from the user manual press the button closest to the seconds display on watch . bottom right button in normal time display to switch between am / pm time or 24 hundred military time.
http://mygshock.com/casio-manual/548/
enlarge the internet browser display to read which button to press to change the time or date.
press button B top left button to go into change mode
press button C bottom left button to move to seconds or minutes or hours .
press button A bottom right button to advance the time
press button b top left button to go back to normal time display
Jun 01, 2018 | Casio Watches
How to Quit military time on Armitron IW-YP 12585A
Hi Bill.
Please allow me to try to help you.
Here is where you could find the answers to how to quit military time on Armitron IW-YP 12585A...
https://oureverydaylife.com/how-do-i-change-from-military-time-on-my-armitron-watch-12277699.html
http://office.manualsonline.com/support/armitron/clock/how-do-i-switch-from-military-time-to-normal-time--5401972
You could also find help in the form of the video that I have added here.
Hope that helps.
Best wishes. Regards.
Nov 06, 2017 | Armitron Watches
How do you change the time from military to standard on a digital scoreboard clock?
can not say as do not know what make or type watch you have .
Oct 06, 2017 | The Watches
To be able to change to analog time from military time
Go to your events/calendar. Click the little settings symbol there. Then uncheck 24-hour time and save. How do I change my clock settings from military time to regular time.
just found this on the internet dont no if this will help you out if not let me no.
Nov 19, 2016 | Able Watches
How do reset a shake n wake to 24 hour time
SHAKE N WAKE: TO CHANGE TO MILITARY TIME
Hit Mode 3 times to set the time
Hit Reset/TimeSet twice to make hours flash
Now keep hitting StartStop/Adjust repeatedly. After you go through 12 hours of AM then 12 hours of PM it will start going through the hours in military time.
Mar 12, 2014 | Maxi Aids Shake n Wake ZZZ Vibrating Alarm...
Turn off military time
This baffled me for a bit...Finally I just took the batteries out, then put them right back in and it was no longer on military time.
Apr 06, 2013 | Brookstone LEGO Ninjago Kai Mini-figure...
I have a Nexxtech Watch that is both digital and hand driven. I have somehow switched the regular time to a 24 hour clock and don't know how to switch it back. The manual says nothing about it. Any help...
These basic instructions are for most digital watches (and these are for regular to military but you can just follow same instructions to get to oposite) Hope this helps!
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 21, 2010 | Watches
Military Time
Hello I have the same watch and had the same problem. You press the mode button till you get to the point to change the main time, you then press the reset button (bottom button on right side of the watch)to toggle to the hour place, you then cycle thru the time untill the "h" in the top right hand corners disappears and then the watch will be back on regular time.
Chris
Jun 17, 2008 | Bulova Men's Watch
How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Mar 11, 2008 | Timex 1440 Nylon watch
How to set
in order to unset the military time on the watch you must hold down the two top buttons until the the 12 hour format comes back. in order to turn off the alarm you must hold down the two right buttons until they beep..and then the alarm will go off
Jul 12, 2007 | Timex 1440 Sports Aggressor 56014 Wrist...
Freestyle Predator 10 Lap 722 Wrist Watch Logo
359 people viewed this question
Top Freestyle Watches Experts
Arturs Kalnins
Arturs Kalnins
ray gallant
ray gallant
Are you a Freestyle Watch Expert? Answer questions, earn points and help others
