Question about Frigidaire Washing Machines
Machine will fill but will not spin
I tried plugging into different outlet.
It makes no noise on spin
    Sergeant:
  • 311 Answers
Frigadire top loader,works in agaitate but not spin??? i would test your lid switch.theres two on ebay right now for 22.$ part#134101800 if switch tests good may be your motor.it reverses to spin....God bless ,tom
Posted on Jan 09, 2009
After the wash cycle it won't spin or drain and makes a hummin g noise then stops without spinning or draining
there is a blockage on the outlet from the drum
perhaps a sock or something is stuck in the drain
and the pump will pump for so long them error is detected
and it shuts down
this sock or something perhaps plastic or etc
can get into the space between the washing drum and the outer drum
and cause this issue
you only notice it at certain times filling it up will make the garment float
and then it empties and gets sucked down blocking the outlet
its a job for a tech to take out a sock or some garment
and clean the outlet fully
check your waist at the sink is clear and flows well
and the machines outlet filter ...
Dec 05, 2014 | Kenmore Washing Machines
Bosch classixx washing machine won't spin. It fills up and washes - does not drain, does not spin. I have manually drained it and checked the plug - nothing was trapped. Ran the machine again - fills,...
Check the filter if clogged clean it or if not check if pump is functioning. Sometimes pump can' work bse of coins stuck in it or rubber bands from pockets.
Dec 08, 2017 | Bosch Washing Machines
My washing machine has started making a noise when it should spin, and doesn't drain on the spin. It Starts the cyle ok, and drains, but the problem is when it spins. It isn't spinning at speed - it is...
Either your pump or filter or outlet hose is blocked Clean out the filter/pump and make sure the outlet hose is not blocked.
Difficult to help without make/model??????????
Jan 27, 2011 | Washing Machines
Machine filled with water but no nothing.
if you can hear the motor running but no agitation then your motor coupling has broken,,it is between the motor and tranny!
Mar 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Kemore 80 washer will not do anything
First make sure that your outlet is getting power to your machine.  Can you hear any noise at all?  Try advancing to spin cycle and see if it will spin.  If it spins, it could be a water valve not opening to fill the machine.  If not it is probably the timer.
Oct 24, 2009 | Kenmore 24032\24036 Top Load Washer
If i set the load size to extra large, water comes out of the bottom of the washer and the belt starts making a shreaking noise
The noise is from the belt getting wet.
Check the pump inlet and outlet hoses for rupture or loose clamps.
Thanks for using FixYa - a good rating is appreciated for answering your FREE question.
Jul 08, 2009 | Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washer gets no power
are you sure the outlet has power? make certain by plugging in a lamp or something else to the outlet first. the timer does have to get power to turn on the unit, but its not likely it is the problem.
try a different cycle and see if it wont run on any position. like fill, wash or spin. then if your outlet is ok, it could be the timer.
i dont think it is but it could happen. usually if the timer fails, it will work on some cycles but not all of them. if it wont work on any cycle then i would expect the outlet first.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
