I have an e-machine pc and the fan continually runs. Any solutions?
    President:
  • 1,179 Answers
It is supposed to always run when the computer is on to prevent overheating. Hope this helps.
Posted on Jan 09, 2009
Indoor fan will not stop
Seems like the fan relay has stuck (Likely to be on the main indoor PC board) or if the machine was being used on heating mode, the indoor pipe sensor may have failed causing the fan to continue to run. Most air cons on heating mode, will keep the fan running for a few minutes after you switch off on heating mode to cool down the indoor unit before it turns off completely. The pipe sensor signals the main PC board to tell it that the unit has cooled down and can now turn off completely. If either of the above faults occur, the indoor fan will keep running all the time.
Jun 19, 2014 | Goodman CKL36AR36 Air Conditioner
Dell laptop Problems & Solutions
Replace the fan. You'll have to take the laptop apart to do it, or take it to a repair shop. If the fan is not working the laptop will run hot and continually shut down. This could damage your motherboard.
May 02, 2012 | Dell Computers & Internet
PC will not start up all of a sudden. I see the CPU fan running and the power supply tester I used showed it was all right. The boot post does not even initiate.
Its very simple Solution.. simply open cabin cover and take ram out and clean ram slot and ram and wait for 5 min and reinsert ram into ramslot.. and switch on computer... if same problem continues repeat it 2, 3 times.. still problem continues contact me farhan0019@gmail.com
Jun 24, 2010 | Dell OptiPlex GX270 PC Desktop
Continuously beeping and rebooting
Have you tried resetting the c mos?
Take out the memory sticks,reset c mos,put memory back in.
Also is the memory in the proper channel or slots on the motherboard?
Apr 23, 2010 | HP Pavilion a1110n (PX743AA) PC Desktop
Machine will not start up,battery is not working but machine usually runs from the mains,machine starts up but does not make it to the bios,no beeps are detected.
Machine doesnt give beep, if the battery completely fails, you system wont start in battery and will continue to run in the main, incidcating that the battery is failing...
PLease rate this solution
Thanks
Nov 15, 2009 | Acer Aspire 5720-6661 Notebook PC
Cooling fan continues to run after turning car off
Try change the Fan Assy....there a small box with state (Gate) on the upper right of fan assy... it does controling the sped of the fan...
Jun 13, 2009 | 2005 Mini Cooper
Fan runs fast all the time
Chances are you need a new fan or it could be your motherboard is overheating so the fan continues to run. Fans are pretty cheap.
or
If you have the expertise to do so, try opening up the unit, detaching the fan and reattaching it. Maybe when you used the air blower it caused it to sit improperly.
Mar 30, 2009 | E-Machines eMachines Desktop PC
I have a emachine T6420
ohk i also have an emachine make sure you have the moniter hooked up all the way i have had the same problem
Dec 31, 2008 | E-Machines T6420 PC Desktop
Machine emits continuous high pitched bleep and power light flashes blue/red
If working OK, probably means that the temperature alarm goes off because is getting hot the PC. I suggest to check why is that happening. All fans working OK? is the CMOS temperature alarm set too low? check your motherboard instructions booklet- It will tell you what the beeps mean probably in the last pages. Good luck
Sep 28, 2007 | Sony VAIO PCV-RX511 PC Desktop
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
