Question about Mad Dog Multimedia Dominator (MDED1F) External Floppy Drive
Do I need and external power supply?
I have an external hard drive. does this unit need an external power supply?
Your free support is a joke. I will call this problem a loss. Sorry, I will never buy one of your products again. Why can't you aswer a simple question.
Posted on Jan 10, 2009
Cannot connecy power supply to unit
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall.
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My new monsoon vulkano pro initially recognized the external hard drive (500GB) that came with the unit, but now does not. any ideas? I've tried reinserting the eSata cables and rebooting unit without...
There are two possibilities, it is either the drive or the electronics/power supply. Take the drive out of the unit and either connect directly to your motherboard with a known working sata cable including a supply cable from the motherboard supply or buy a sata to usb converter with power supply and plug into the usb port of your pc. You need to know that you can still get the info off the drive. If You can recognise the drive by other means such as this then it is the electronics in the unit at fault or the power supply. Do you have a means of testing the supply such as a test meter to see if is working?
Jan 27, 2011 | EZQuest Monsoon Hard Drive
Lost or misplaced power supply for Beyond Micro Micro Model BMMDU2 External hard Drive. Need info on Wattage input. Please and Thanks if you're able to hrlp.
Well, looks like Beyond Mico web site has gone to the great Beyond.
From units I have been able to find online, it looks like the power supply is between 20 and 40 watts.
The hard drive unit itself should be able to supply you with the required DC input voltage (hopefully there is some kind of label on the enclosure).
You could try one of these or something similar. It comes with 6 interchangeable heads and has adjustable DC voltage. This is just one of many available.
I cannot guarentee any of these supplied heads will fit your particular drive (same with the dc voltage). But some local retailers often have these types of adapters and you might be able to determine what size you need by looking at one.
I have used DC units similar to these in the past when I have lost a power supply.
Hopefully with a minimum of effort you can get a working solution.
Dec 28, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Do I need only one cord (usb) to connect to my laptop?
The "physically-smaller" external hard-drives draw power through the USB cable.
The "physically-larger" external hard-drives require an external power-supply (just like a laptop requires an external power-supply).
Check the casing for a plug where the electrical power would come in; if none, then the unit will draw electrical power through the USB cable.
May 31, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Wxternal hard drive power supply
It may. Take it to an electronics store and ask. I'm not sure
Jan 09, 2009 | Mad Dog Multimedia Dominator (MDED1F)...
WD Notebook Essential 80G just quit working
if you are not getting any broken noise from the hard disk its not ded so ushut down the computer first then connect the hard disk to the power and then connect the hard disk to your system in the usb 2 port then connect the start the system if still dosent detect go to manage by right clicking on the my computer icon the go to disk management check your hard disk shows ther if shows forign just right click on the forigen and say import forigen hard disk if shows the drive helthy and dosent show up on my computer then just right click on the helthy place and say change drive letters and choose one of the letters and should show up on the my computer if still dosent see at all then change the usb cable....
if still dosent work remove hard drive from the external case and put it directly to your computer for this u need a sata cable and a sata power if it detects and work this way your data is safe but you casing of the external hard drive has probs ...
Nov 12, 2008 | Western Digital 320GB MyBook External USB...
SmartDisk Crossfire Desktop Drive
Usually this is a problem with the usb port not being able to supply enough power to the drive. Often, units like this will come with two usb plugs on one cable to increase the current supplied to the drive. If the drive has an input for external power (some do, some don't), then using external power would help.
Apr 23, 2008 | SmartDisk Crossfire Desktop (xf160f) 160...
Center Pin External Power Polarity
Problem is just external...First try in another pc,if it still wont work so just buy new external and put that hdd in new external...
Jan 21, 2008 | FireLite (USBFLB80) Hard Drive
Mad Dog Multimedia Dominator (MDED1F) External Floppy Drive Logo
95 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
