Question about iLO 2600 Television
No buttons on the tv function only the power button?
    Problem Solver:
  • 8 Answers
Use the remote, go to MENU, look for a setting to unlock buttons. I had this problem on my InFocus TD40.
Frank
Posted on Jan 10, 2009
How can i fix a rca tv, mod. 27v412t cuts on and off?
this kind off problem is related in power circuit board or may be the main board ,kind of electronic problem, not mechanical ,related with electrolytic capacitor,may be two or three or one,this is dried up capacitor,or devalued capacitor in rating or leaky capacitor,or broken leg capacitor,one pin break in the bottom of capacitor main causes are heat or power serge or getting aging old ,because these capacitor not functioning ,therefore no enough voltage for on off TV function,so TV wont come on,some times come on,some time press power button lot of time then come on,now it wont come on at all completely,these or the symptom of intemittent power button function,peoples think that button have only the problem and replaced the power switch only and tv should work ,but deep down lot of work in circuit board analysis and repair work needed.,to make TV function normally.
May 10, 2014 | GE 31GT740 31" TV
Hitachi 55vf820 problem
Most likely the buttons on the tv are stuck or malfunctioning, replacment of the button pannel will solve the issue
Mar 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
How do i get my dishnetwork remote programed to my world tv
Janicesim851, Programming the remote is pretty simple.
We don't have any codes for a World TV available, though you can check out this link for more information
http://www.dishnetwork.com/SupportSection/remote-setup
In case you already have a code available I will provide both instructions to address the remote, and how to power scan the code in.
Addressing Remote to
TV: 1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Power Scan to TV:
1.) With the TV on, press and hold the TV button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press and release the red power button, then press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, it will power off.
3.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Let me know if you have any other questions!
Tommy Faust
DISH Network
Jul 21, 2011 | DISH Network IR Remote Control
My dish remote will not work with my naxa tv
Hey sevenwindham,
If the remote won't work it may need to be programmed to the TV. You can personally look at the steps in the link below, just look up the model of your remote. The steps to program your remote are also provided
Addressing Remote to TV:
If that doesn't work you can also try the Power Scan listed below.
Power Scan:
1.) With the TV on, press and hold the desired mode button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press 0 then press STAR (*) and press and release the Power button.
3.) Press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, the TV will power off.
4.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
If you have any other questions let me know!
Tommy Faust
DISH Network
Jun 15, 2011 | DISH Network IR Remote Control
I can turn on my haier tv with a dish network remote.I need a code for it when it off from the buton I can not turn it back on with the button
Hello! I recommend that you try a programming method called a Power Scan this will allow you to search for a code and try the functions as you go. If you only receive partial functionality please repeat steps 2 and 3 until you find the code that works. If there is no functional code the TV button will flash rapidly.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Jun 05, 2011 | Haier HL32D1 32 in. TV
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
I have an sony rm-ez2 and i want it to work with my orion Model #tv1934 whats the code or will it work
As far as I can tell, Sony doesn't have any codes for Orion TVs. You can try searching through all of the codes in the remote. Turn on the TV, press and hold the Set button and then press the Power button. Release the buttons. Then press TV button (component button). Press the CH+ button followed by the Power button. Repeat the CH+ and Power combination until the TV responds (powers off, changes channel). Then press ENT. Check if the TV responds to the remote on other functions. If it doesn't repeat the steps from press and hold the Set button.
This can take up to 70 tries.
Alternatively, try a replacement remote for the TV or a USB programmable universal remote. http://www.remotes.com/store/orion/tv1934.html is a substitute remote that should handle all of the functions.
I hope this helps.
Sep 06, 2010 | Sony RM-EZ2 Remote Control
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Apr 26, 2008 | Sanyo DS32224 TV
Konka tv code
Try "auto search" with your remote. Normally you press the TV button and the "OK/Select" button simultaneously for about 3 seconds untill the TV light burns steady. Then press "channel up" one press at a time untill the TV turns off. When it turns off, then press "power" on your remote and if the TV comes back on, test the other functions such as volume and mute. If all functions work, then press the "TV" button one more time to save the code and then you are "in business". If functions do not work, then continue to press "channel up" untill the TV shuts off a second time. Then press "power" and test all functions. Continue repeating this until you find a code that enables all desired functions. Hope this helps.
Keever
Mar 04, 2008 | Televison & Video
Televison & Video Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
