Question about Toshiba 50HDX82 50" Rear Projection Television
About the 50hdx82 hyper issue
Are you sure the issue is the hyper module? I just want make sure that's what it is.
  • 934 Answers
From what you've described, yes sounds like the hyper module. And that's a fairly common problem with those symptoms...
Bill
Posted on Jan 10, 2009
Tv is pulled in on sides
Replaced the 2 convergence ICS in the hyper board u well solved this problems.
Feb 12, 2010 | Toshiba 50HDX82 50" Rear Projection...
Toshiba 50hdx82 tv touch focus error blue is bowed.
Convergence is dead.Know how to solders.Must replaced the 2 Convergence ICS,and all it resitors.To do it ur self repair buy a convergence kit at Tv repair World.com,Repeairkits.com.The shop will cost u $300 for parts and labors.
Feb 04, 2010 | Toshiba 50HDX82 50" Rear Projection...
The picture is all waves ,I get sound and color but the picture is all lines and waves,what part should I get??
To fix the shaky picture on the toshiba rear projection tv model number 42h83. You need to either replace the 13 capictors on the hyper module or simply replace the hyper module itself. It's cheaper to replace the caps, but you'll need decent soldering skills to do this. You can replace the entire hyper module with less soldering skills, but I believe the module costs about $100, maybe alittle more. You can find the entire fix by googleing "hyper module". Good luck and I hope this helps
Oct 21, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 50hdx82 the top and bottom of screen hour glass shaped
This is a convergence problem. If you wish to attempt the repair and are comfortable working inside the set, please update this and I will supply additional details and instructions.
Thanks,
Dan
Oct 21, 2009 | Toshiba 50HDX82 50" Rear Projection...
Same Problem
sounds like the Hyper module as it can cause that type of symptom when the Capacitors are getting weak
Jun 23, 2009 | Toshiba 50HDX82 50" Rear Projection...
50hdx82 video shaking
It is the Hyper board gone bad. There 11 10uf 16v cap's that go bad. They are very small surface mount type 4mm in size. They are cheap but hard to solder in. There is a guy on ebay who is rebuilding them for $75. Just search this part number: MVPU14 that is the hyper board.
Feb 08, 2009 | Toshiba 50HDX82 50" Rear Projection...
50HDX82 rear projection Flicker/Fuzzy and Vertical Purple Lines
The hyper module itself is not an expensive repair about $70 to $100.00 dollars. The tech will simply be replacing about a dozen 16v/10mf smd caps and re-installing it on the signal board. But that doesn't address what he has to do to get to it and get the hyper board off and back on the signal board and that is a bit time consuming.
What I would suggest is to call around to the various shops and ask what they charge for the hyper module repair and see if you can get an off the cuff estimate for around $250.00 dollars.
If you need help finding some reputable shops try TVrepairpros.com for help in finding some of the best technicians available.
Bill
Jan 09, 2009 | Toshiba 50HDX82 50" Rear Projection...
Toshiba 50HDX82 screen flickers at the top
Replace the Hyper Board, There 11 10uf 16v cap's that go bad.
Common Problem with this set
Nov 25, 2007 | Toshiba 50HDX82 50" Rear Projection...
TOSHIBA 50HDX82 - hyper board failure
Toshiba likes to solder shields / covers in place.......check..
Small boards have a side clip = release with screwdriver while
releasing end clips = hard to describe, best to visually inspect.
I will let you know about service literature = CD ROM.........T.
Nov 07, 2007 | Toshiba 57H82 57" Rear Projection...
Wavy picture on all sources
This is a somewhat common problem having to do with the hyper module, Toshiba p/n#23148024 There are a gouping of 16v/10uf caps in the hyper board that fail causing the distoritions you're describing here. At first, as the module begins to go bad the distoritions are present and usuallly go away or fade significantly as the set warms up - - this gets worse until the distoritions don't go away at all... From what you're saying you're at stage three already. :) You have a few of options: (1) local repair shop pull the board and replace the caps or module; (2) Pull the module yourself and repair or send it in for board level repair; or (3) pull the hyper baord, order a new one and put it in yourself. For 2 or 3 you'll be better off having the service manual and if you need it just email me privately and I'll send it. Make sure in your request to tell me the model number and reference something of this repair so I have a clue of what you need. BTW the hyper board is on the left side of the unit mounted vertical on the signal board inside a metal can. Good Luck Bill
Jun 10, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 50HDX82 50" Rear Projection Television Logo
129 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
