Question about Xerox WorkCentre XD105F Laser Printer
Connecting printer I have an old xerox printer and a new computer. The comouter has only usb and a 13 pin connector, the printer only has a 25 pin parallel cable. Does anoyone know if an adapter is available? Xerox xd105f
  • Anonymous Apr 11, 2009
    I have purchases the adapter but I am unable to install the download for Vista. I get error messages which say:
    This file does not have a program associated with it for performing action. Create an association in the set associations control panel.
    Application error ISSET_SE caused a general protection fault in module167f; 02253/4 l l ISSET_SE will close
    and
    Setup is unable to run a Program needed to proceed with the installation. Restart your system and try again.
    I restarted my computer several times.
    Can you help?
    Thank you in advance
    President:
  • 8,637 Answers
You can purchase an adapter "Parallel to USB" for printers to be used with printers.
http://accessories.us.dell.com/sna/productdetail.aspx?sku=A0489585&cs=04&c=us&l=en&dgc=SS&cid=30098&lid=674094
Hope this helps. Bud
Posted on Jan 22, 2009
What is a serial port and where is it on the p67 mb
a serial port is a 9 pin (DB-9) connector for serial communication (RS232) used by modems, mouse, etc... In older machines you had a DB-25 (25 pin connector) as well usually situated in the back of the computer near the printer port (DB-25 connector) but femail (25 holes insdead of 25 pins)
Hope this helps!
Aug 06, 2011 | ASUS P4P800-VM Motherboard
What printer do I use to connect an Officejet d135
A printer does not connect to a hard drive.
Is the connector on the PC a Male (Parallel) or Female "D" (Serial) shaped connector?
Does the PC have a flat USB connector you can use?
If it does, then you should be able to purchase a cable that has an "End Point Connector" The "U" shaped block and the other end is the flat conector that is oon just about everthing.
Don
Feb 06, 2010 | HP OfficeJet D135 All-In-One InkJet...
Can I connect my HP laserjet 5p with a 25 pin connector to my laptop which only has USB connection
On the back of the printer where the cable connects is actually a 36 pin connector, the end going to the computer is the 25pin end. What you will need to do is get a USB to parallel cable, they run $15-25, this will have the USB plug on one end and the 36pin centronix printer connection on the other end. This cable will allow your printer to be connected to the laptop. Office Depot and Staples should have the cable you need, if not you can do a google search for it and order one online.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | HP LaserJet 5p Printer
I just installed my designer software onto a new computer that doesn't have a 25 pin printer cable, however, I bought a usb/25 pin cable and have the dongle attached...but the software says the dongle...
Your software still is looking for the 25 printer pin connection from the motherboard. I don't know computer set up from an engineering concept, but I do know that the usb connection you purchased doesn't work with that software. You'll need to either get the new software or a used computer with the printer port hook up.
Nov 01, 2009 | Husqvarna Designer I
XD100 Won't work with USB
check the usb port boot computer and printer..or parallel to usb or usb to parallell try it..
Sep 14, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Need a cord to connect OLD computer to NEW printer
You can take the cord to Radio Shack and get a 24 pin serial dongle to 9 pin dongle. take a picture of the back of the computer and of the cable if you have and they can find an adapter for you. Thanks for using fix-ya and rate this if it was helpful.
avid101
Aug 24, 2009 | Xerox XG-91D 19" LCD Monitor
Bios password reset for toshiba lap top
You need to build a hardware device that plugs into the printer port.
Get a 25 pin male D sub connector, and solder various wires
to the pins numbered below. The pins on the connector are numbered 1 to 25
For a picture of this hardware device (dongle) go to :-
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg
Connect these pins together by soldering thin insulated wires to the following pins :-
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the dongle in the printer port and boot up the laptop, you will then be able to bypass the BIOS password and go into the BIOS to reset/remove the password.
Mar 08, 2009 | Toshiba Satellite Pro M10 Notebook
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Xerox WorkCentre XD105F Laser Printer Logo
111 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
