Question about Samsung DynaFlat TX-P3071WH 30" TV
Interesting problem Previously this TV would turn off after running for sometime. No sound not picture. I looked in and visibly found that the capacitor after mains rectifier was kind of bulged out. Replaced with a new one (820microFarad/250V) and then turned it on. It did not. But then pushed main board up a little and it started up. Left it running for a few hours, it did not turn off (like it was previously). But when I tried to turn on after some time, it does not turn on. Any ideas??
  • shailesh valera Jun 07, 2007
    Thanks 1Beertap, I am going to try this in short time.
    Will let you know ...
  • shailesh valera Jun 21, 2007
    1beertap
    YES!!! That was it!!!
    I tried re-soldering aroung the fly-back, I actually found one of the solder point kind of not ok, you see and you know that it is not ok kind of not shiny, and several more and then wired the board back in and it just turned on wihtout any problem!!! and runs just fine...
    Thanks a lot for the solution!!
    Silas
  • 32 Answers
It sounds as if you have a cold solder joint. I would check for bad solder joint(s) around the flyback transformer as this can be a common problem in some televisons.
Posted on Jun 04, 2007
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
VISABLE LINES IN PICTURE
Bulb replacement will only repair reduced brightness or contrast problem. Sometimes shadows or lines (usually curved or circular) appear in the image if the bulb is weak or faulty. This will show with the color turned off and a black and white image displayed.
Most visible color faults are caused by optical engine failure. Big cost, as the complete assembly has to be replaced.
Occasionally there are video processing or tuner problems that require serious troubleshooting to determine what board has to be replaced.
If the fault is not visible on the customer menu and appears only with input signal viewed, you may have a cable box or other signal input problem. Check various input signals to see if the problem is visible with all inputs.
Running the channel scan with vhf input signals sometimes clears up a lot of problems. Your cable company may have changed or adjusted rf modulators or other equipment and the tv needs to be aligned to the changed signal. Auto tuner scans will take care of these problems.
easyab
Apr 22, 2010 | Panasonic PT-50LC14 50" Rear Projection...
2 year old LG Flat screen TV keeps freezing
It is not your tv its channal 9, switch off totally at the wall, disconnect aerial, turn on - tune into channel other than 9, plug in antenna again
Feb 04, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Unexpected Golden Line?
Looks like uneven spread of developing chemicals to me - try a different (new !) film pack.
Mar 20, 2017 | Polaroid OneStep Express Instant Camera
Picture and sound problem at 21" sony waga color tv
This is not a simple question to answer without looking at it, my recommendation is to call a service center in your area. That's my professional opinion.
Feb 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
WEstinghouse TV Bright white screen
contact the mfg about their warranty
Jul 13, 2008 | Televison & Video
Samsung DynaFlat TX-P3071WH 30" TV Logo
117 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
