Question about Frigidaire Model: PHSC39EHSS
Frigidaire PHSC39EHSS2 Hi, I'm in Canada and own the above fridge. My temperature display was in Celsius until it was unplugged today for leveling. When it was plugged back in, the temp display is in farenheit. I've been told that the display doesn't show in celcius, but I'm positive it was in celcius before because the current farenheit display won't go lower than 33 Farenheit for the fridge and my display used to show 4 celcius and I could turn down the temperature below 4. I called the manufacturer and spoke to someone in the US and they said that the display can't show celcius, but I'm sure it did before. And, the manual doesn't have information on how to change the display, but it does show the min and max temperatures in celcius!
  • sugarcanegin Jan 10, 2009
    Hi MrCaesar, I've tried that and it doesn't seem to work unfortunately.
  • MrCaesar May 11, 2010
    Try holding down the freezer temp up and temp down buttons for 5 sec or fresh food temp up and down buttons for 5 sec
2 Suggested Answers
dniro592006
  • 121 Answers
SOURCE: centrigrade to farenheit
Read the manual
Posted on Nov 01, 2010
How to change the temperature display from Celcius to Farenheit
Hello Friend, that's a great question!
Please follow the steps below to change the temperature to Celsius to Fahrenheit on your Frigidaire range, FEF366CCA.
    ·Press BROIL. "-" appears in the display.
    ·Press and hold the UP arrow until "HI" appears in the display
    ·Press and hold BROIL until F or C appears in the display.
    ·Press the UP arrow or DOWN arrow to change F to C or C to F.
    ·Press any control pad to return to normal operating mode.
    Hope this helps! - Z
Sep 03, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
How do you change from celsius to faranheit on a frigidaire refridgerator model no. phsc39ehss2
Good Afternoon Friend, this is Z. That's a great question!
If your display is showing Celsius opposed to Fahrenheit on your Frigidaire refrigerator (PHSC39EHSS2), here is what you will need to do.
Press and hold the fresh food UP arrow while pressing the freezer UP arrow three (3) times within 5 seconds.
Best of luck!
Jul 18, 2014 | Frigidaire Refrigerators
Temperature on display will not go down
HI PAULA.this is too new but the fact that it went wrong after the power cut indicates that the power surge has damaged the pcb board.try manufactures warranty.good luck.Ali
Aug 21, 2012 | Frigidaire Refrigerators
MY OVEN IS VIKING OVEN CAN YOU PLEASE TELL ME HOW TO CHANGE FARENHEIT FROM CELCIUS
Hi and welcome to FixYa, I am Kelly.
Here is how you change it:
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
Mar 22, 2011 | Microwave Ovens
Hi Ekse This is a test. How is the weather up there?
Near Flin Flon (Manitoba, Canada) the overnight temperature was MINUS 24 CELSIUS, and the high today is predicted to be MINUS 14 CELSIUS.
Take a glass of hot water, and throw it up into the air, and it will freeze in the air -- it won't wet the ground.
Dress warmly!
Mar 03, 2011 | Computers & Internet
I am trying to return the freezer and refrugerator settings to 37 and 0 , how do I do that?
There is a dial or button pad inside the fridge that controls the temperature up or down.
some displays are not so clear so just adjust your fridge slowly either way until you get to the desired temperature
37 degree Fahrenheit = 2.78 degree Celsius
0 degree Celsius = 32 degree Fahrenheit
Oct 28, 2010 | LG Refrigerators
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Celsius to Farenheit issue
Maybe we can trade ovens!! Mine is in Farenheit and I'm trying to figure out how to put it back in Celsius!!
Armen
Montreal, QC, Canada
Dec 04, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
Frigidaire Model: PHSC39EHSS Logo
266 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
