Question about RCA D61W20 61" Rear Projection Television
The tv does not work
Tv repair place called it a flyback or something like that...it powes on then makes a wierd noise then shuts off...then does this 2 more times.
  • 1 more comment
  • p_id_1972 Jan 09, 2009
    how much would that cost,,,i dont know if i should have it fixed or buy a new one
  • Anonymous Jan 09, 2009
    i have the same problem on a GE 52'' thats an rca in side i replaced the fly back and no help whats the yoke and h.o.t. also if we heat up area in the center of speakers[with out panel on] it starts everytime,so it has to do with being cold.were in ohio
  • Anonymous Feb 05, 2009
    Is this something I can fix
    Champion:
  • 240 Answers
Yes flyback and yoke and h.o.t all should be replaced.
repair shop was right.
Posted on Jan 09, 2009
Makes repeated popping/clicking noise when plugged in. like the sound it makes when first turned on.
sounds like the power supply is oscillating or the safety circuits are shutting the supply down and the restart circuits are starting things up again. Either way, you need to have this TV inspected by a professional repairer. The power supply is capable of supplying several hundreds of volts, more then enough to give you a nasty shock or KILL YOU !!!! The safety circuits are there to shut the tv down if something goes wrong, which can include dangerous levels of x-rays and other electromagnetic radiation, a faulty flyback transformer or EHT transformer can cause a fire.. So please, have it checked by a qualified tech..
Dec 25, 2009 | JVC AV-36D303 36" TV
I changed the bulb in my tv and it was working for a few days. Now I get audio but there is a wierd electrical clicking noise which made me think the new bulb broke but I still have a green light on the...
In this case there are two possibilities of what part is the one causing the issue, it coul be a ballast because of the clicking sound that caused the tv to shut off, and that buzzin sound is for your color wheel that it might not be working anymore, discountdashmerchantdotcom free troubleshoot
Jul 24, 2009 | Mitsubishi WD-65733 65" HDTV
My 32v434t television.
The TV was making the clicking noise and not turning on because an internal error was being detected.
Now things had got worse , and something had blown inside the TV.
The burning smell and high pitched noise is coming either from Flyback transformer or PSU board. Repair is a delicate matter and must be done by a technician.
Jul 05, 2009 | RCA TruFlat 27F520T 27" TV
TV Just Started Making a Humming/Buzzing sound
Replacing a flyback is not something I would suggest for anyone with no electronics experience. Second, lets see where the noise is coming from first. Take off the back and listen to the noise. The flyback will be at one end of the large red wires that go to the tubes. Sometimes the connection at the tube is not 100% and the noise comes from there. BE CAREFUL - there are high voltages going through this red wire that can be dangerous even with the set UNPLUGGED!! IF the noise is coming from the connection at the tube, with the set unplugged, carefully turn the rubber cap back and forth touching only the rubber part with one hand. Put the other hand in you pocket while doing this.
If the noise comes from the flyback side, if you can solder, again with the set unplugged, try resoldering the pins on the transformers. That may resolve the problem.
Keep me posted.
Dan
Feb 13, 2009 | Samsung HCL5515W 55" Rear Projection...
Tv sparked and made noise and shut off rca model f32648
Looks like the projection is fried. I'm afraid you would have to exchange for new one if you can or purchase new Tube.
Jan 28, 2009 | RCA F32648 32" TV
Model number d52w27d when turning on tv the powe light will flash about three times but dose not turn tv on
you need to replace the flyback, you need flyback number 259296 you can get a replacement at the following link with free installation help so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Aug 29, 2008 | Televison & Video
Shuts off
Reedasaurus resolder your flyback.
Neednonrcatv, you need a new flyback you can get one at the following link with free tech support so you can install it yourself, very easy repair you need flyback number 259296 heres the link.
Apr 22, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCA D52W19 power problem
these set is what i like to call VAlue sets.. you can get these for 800 at walmart. If you smell something theres a good chance its what is called a flyback transformer... i repair that averages about 300 to replace. Caution it may be more. DANGER, Do not attempt repair of set unless qualifed to do so tv generte high and leathal voltages.
Jan 01, 2008 | RCA D52W19 52" Rear Projection Television
Wierd sound when I switch on the TV
Your TV may something arcing inside of it. Maybe a loose connection. Since it is probably under warranty you should get in touch with the dealer where you purchased it. Perhaps you can get the whole TV replaced. Stargazer
Feb 20, 2007 | Samsung SlimFit TX-S2783 TV
RCA D61W20 61" Rear Projection Television Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
