Question about Acer Aspire 5720 Notebook
Connecting an external monitor to acer 5720
I have an external monitor I used to use with my acer 5720 but when I went to connect it recently the external monitor goes straight to standby and my laptop monitor goes black but I still have sound. The monitor used to work fine with this laptop and still does work fine with every other computer in the house. I must of changed some settings somewhere but cant figure out what I've done? Help please :o(
    Problem Solver:
  • 6 Answers
I have had this before with my Dell Latitude C540/640. I don't know the ACER 5720 but here's a couple possible fixes for you.
1. Press the function key ( "fn" key, generally a blue key or blue lettering and usually in the bottom left corner of your keyboard) and press F8 (may be a different key on your laptop, again, not familure with the acer. The key usually has either CRT/LCD printed on it, or two monitors on it, one its just an outline of a monitor and the other is filled in. This will run you laptop through the three monitor options it has. (LCD - LCD & External - Just External)
2. Try closing and opening the lid of your laptop. Sounds a bit strange but it works sometimes for me. My guess is when you close you screen it would "dim/turn off" the LCD and re-opening it convinces it to turn the screen back on.
Hope this helps!
-David-
Posted on Jan 09, 2009
Is it possible to connect the Acer travelmate 2300 series to the monitor after connecting what can I do is there any functions key to works the monitor
If you connect the monitor, power on the monitor then boot the laptop, it should default to the external monitor.
Jan 04, 2016 | Acer Computers & Internet
No display in acer extensa 4620
Hi There,
Check the below link that might help you to diagnose the issue:-
http://laptopturn.com/acer-extensa-4620-wont-turn-on-wont-boot-no-display-black-screen-problems/
Hope this will hep to diagnose the issue if it is VGA cable that is faulty of something else.
Jan 27, 2018 | Acer Extensa 4620 Notebook
Have an Acer Aspire 5000 and recently had the OS reinstalled. Since then, the Fn F5 button to switch to an external monitor doesn't work. The only Fn button that seem to work is the touch-pad or Fn F7...
can you switch to external by going to control panel > personalize > display settings and making changes there. and what are you connecting to projector, or another monitor?
Feb 17, 2011 | Acer Aspire 5000 Notebook
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
Just changed the LCD screen on a 5720 and all I get is the backlight and a light blue screen....is there a reset or something i missed?
connect to an external monitor, and boot your system, and install the drivers for your new monitor.. should work.
if not, then the compatibility of the new monitor you hooked up, isn't good.
Sep 16, 2009 | Acer Computers & Internet
CHILD DROPPED IT NO SCREEN BUT WORKING
you con get a new LCD monitor using this information
http://www.acerweb.co.uk/aspire1520.htm
or
to enable an external monitor you will have to switch it on by right-clicking on the desktop
( i dunno how much of the screen is blind/which corner you still see)
then goto display - properties - advanced - monitor : her you should be able to switch to the external monitor.
good luck
Aug 04, 2009 | Acer Aspire 5720-6661 Notebook PC
ACER 5720 WIRELESS CONNECTION PROBLEMS
Are you using security?
If you are try changing between wep, and wpa
If that still does not work use mac filtering
May 27, 2009 | Acer Aspire 5100 Notebook
Connection to external monitor stopped working
Did you go to the display properties screen and check the settings of the second monitor connection. You must turn it on, and have it set to a low enough resolution for the monitor to work. If it shows the second monitor, Click Identify and it will put a number on the laptop screen. Which ever number doesn't show up is the external monitor. Select it and set the resolution down by grabbing the scroll bar and drag it to the left. Start at 800x600 or so and apply changes. If the monitor doesn't come on, check to see if the monitor is on.
Mar 30, 2009 | Acer Aspire 5720 Notebook
Connection TV to computer using S-cable
On my laptop to toggle between internal and external monitors I have to use the FN + F5. you might want to check which F1-F12 button controls monitor function.
Apr 16, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5720 Notebook Logo
402 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
