Question about Mamiya RZ67 ProII Medium Format Camera
Mamiya RZ67 mirror stuck open
I just shot the last frame of film on my Mamiya rz, and the film lever would not pull down to advance the film. So I rolled it with the round winder on the film back, which worked. When I changed film, the lever would still not go down, so I wound it to the start of the roll with the round winder on the film back again. Now the camera will not fire. When I took the back off, I see that the mirror is stuck in the up position. What happened? How can I fix this?
spotatohead
  • 95 Answers
SOURCE: Mamiya RZ 67 lens is stuck on body
This is likely because the shutter has not been cocked all the way. Return the lens to the fully locked position and advance the film with the lever all the way down to reset the shutter. If it still doesn't work, move the lever to M for multiple exposure, make sure the back is aligned and trip the shutter release. Then fully **** the shutter again by pressing the advance lever down fully and again until it is reset. Then try to remove the lens again.
Posted on Dec 16, 2008
mail541
  • 58 Answers
Solutions here....
http://www.apug.org/forums/forum51/16253-mamiya-rb67-lens-stuck.html
Posted on Jan 22, 2009
ttriolo
  • 5 Answers
SOURCE: My Mamiya RB67 triggers and shutter lease lever
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Posted on Nov 14, 2009
cammedic
  • 667 Answers
SOURCE: Pro-S film back doesn't advance film properly.
There is good chance that the back needs a spring replaced. I've seen them fail many times.
Posted on Dec 07, 2009
SOURCE: pentax me super mirror in up position
If the batteries are flat or missing you wont get LED's to light up and it will set itself to 125 naturally. I know as I have tried it. It could be that the shutter has got stuck on its way down and it is preventing the mirror from coming down as a result this is a mechanical issue, not battery related. The best way I found to release the mirror was to gently, really gently stroke the shutter nearest to the film down towards the groove it goes home in. Recommend a cotton budd so you don't damage the shutter leaves or get grease from your fingers on the movement. This should release the mirror. The next thing to do is try preventing the shutter getting stuck again by removing the bottom plate which will allow you access to the cogs for the shutter. it is tight in there and it is recommended by some that you remove some of the movement to see and clean them up. I did this but it is tricky and it involves winding on the camera and rocking parts out with itself. Not easy to do. The shutter cogs are brass (or look like it) and they may have old oil stuck inbetween the teeth which needs cleaning out with a tooth pick and then lubricate but not with WD40 which gets sticky with age. Use a cotton budd again with the lubricant on so you don't affect other sensitive parts around this section. Alternatively send the camera for a good service. I just had mine done, got it sorted with a warranty for 12 months to and cost me just £45. They cleaned everything up, new light seals and sorted issues common to this model of camera. The photos are instantly back to their best. Compare a good service to a series of wasted film with an inconsistent camera. Peace of mind too, it is worth it and so is the camera!
Posted on Jun 02, 2010
I just bought a nice used Mamiya twin lens C3 but the shutter is locked up. There is a small metal piece holding the shutter release from moving. Not sure how to un-lock, seams to be a safety device of...
The vertical shutter sliding lever gets locked if the film doesn't get advanced to the next frame, and the mode selector is set for single exposure. You can't trip the shutter unless you have film in the camera and you forward the film to the next frame. That should allow you to release the shutter with the sliding lever.
Mar 17, 2014 | Mamiya Cameras
My Mamiya C330 Pro only gives me 4 photos per roll
A few things to consider:
-Loading: Make sure you are not over loading the film before you start to shoot. I have sometimes turned the film advance too many times and end up cutting down on the amount of usable film.
-Are you loading the film in a dark area and careful to close up the back just after it has started to load to avoid exposing it?
-Shooting: Are you metering properly when shooting? Obviously underexposed images won't develop. You should consider a hand held meter.
-Shooting: Are you advancing the film more than it needs to be after you take your shot? Watch the film counter and feel for that click as it hits the next frame. I have advanced past the next shot many times by accident.
Hope that helps, Matt
Apr 05, 2011 | Mamiya C330 F Professional TLR Film Camera
My mamiya rz67, which i have never used before, is making this long high pitched noise. i also dont feel the shutter is firing correctly.
Change the battery! This happened to mine too, I was terrified... never knew it took a battery until then, as I don't have a viewfinder with an inbuilt lightmeter. Unfortunately the rz needs it just to run, this is where the rb actually wins. The battery is underneath, you should be able to get a new one from a camera shop.
Dec 18, 2010 | Mamiya RZ67 ProII Medium Format Camera
I have a mamiya RZ Pro two and I am looking to find a digital back for it. If you could offer any guidance and advice I would be very greatful as there seems to be very little help for th RZ film...
Currently . You need a digital back adapter (approx.$1500.00+ US) then the digital back itself (Approx. 25,000+ US). yes that is correct!. THe RZ67 Pro II needs the DM56 adaptor then the DM 56 back itself. Why not check out the all new RZ22 (22mp) or the RZ33(33mp). The RZ22 is approximately $12,000.00 US and the RZ33 around $18,000.00. Hasselblad also make a 39 and a 50mp digital medium format, expect to pay 2-3 times that of a Mamiya. For a 35mm type dSLR, Nikon just introduce the D3X with 24.5 megapixals. The body alone runs anywhere from $6,500-$8000 US.
Sep 12, 2010 | Mamiya RZ67 ProII Medium Format Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
RZ67 with new battery, lens set, 120 film back set but we get all the time a yellow led warning and the shutter does not work
A yellow led indicates the wind lever isn't cocked, or a weak spring hasn't returned it to the fully up position. A red led says pull out the dark slide.
Oct 16, 2009 | Mamiya RZ67 ProII Medium Format Camera
Dec 15, 2008 | Mamiya RZ67 ProII Medium Format Camera
Mamiya RZ67 ProII Medium Format Camera Logo
567 people viewed this question
Top Mamiya Photography Experts
Tony
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
