Question about Epson Stylus 880 InkJet Color Printer
Difficulty printing pictures
I'm trying to print 4" x 6" pictures, but the size option refers to letter, envelope, A4, A5, B5, & so on. Nowhere can I find the size I need. The problem just started after the printer was installed on my new computer, with Vista. The printer was installed where I purchased the computer, & shows in my control panel as an Epson 880 (M). Was it installed incorrectly? If not, how can I find picture size options?
  • 514 Answers
When you get to the point where Epson print screen comes up, click on the "printing preferences" button, then choose the "paper" tab, and click on the "paper size" box, scroll down about half-way to "photo paper 4 x 6" and select. then check which orientation that you want and print away! good luck!
Posted on Jan 11, 2009
    President:
  • 1,179 Answers
Does irt have a photo media option? You can find all the info about changing paper sizes & media here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14374&prodoid=11473&category=Products
Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 09, 2009
Where do I load paper in a Kyocera FS-C5350DN Full-Color Laser Printer
At the bottom of the printer you will find the paper cassette. Pull the handle and the cassette will slide out. Eventualy you will need to ajust the size of the paper.
Jun 23, 2014 | Kyocera FS-2000D Laser Printer
I have a canon mp 240 and it Prints fine if you only need half of the document. It cuts everything in half! Like it reads the header wrong or blows up the words or make extra spaces. How can I get it to...
I thought maybe you have the paper size set to Landscape rather than Portrait. If not, then you might look at:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport
I did some searching on that site and it yielded the hlep below which may give you some help.
Issue: How do I set my printer so my printout fits the paper size I am using?
Solution: Use the recommended Print Area MP240
Printing Area title-bar.gif To ensure the best print quality, the machine allows a margin along each edge of media. The actual printable area will be the area inside these margins.
Recommended printing area (dark blue):
Canon recommends that you print within this area. (o_darkblue13.jpg)
Printable area (light blue):
The area where it is possible to print. (o_lightblue14.jpg)
However, printing in this area can affect the print quality or the paper feed precision.
o_area15.jpg i_note.gif Note
Borderless Printing
By selecting the Borderless Printing option, you can make prints with no margins.
bullet_s.gif When performing Borderless Printing, slight cropping may occur at the edges since the printed image is enlarged to fill the whole page.
bullet_s.gif For Borderless Printing, use the following paper.
- Glossy Photo Paper "Everyday Use" GP-501
- Photo Paper Glossy GP-502
- Photo Paper Plus Semi-Gloss SG-201
- Photo Paper Pro Platinum PT-101
- Photo Paper Plus Glossy II PP-201
-Photo Paper Pro II PR-201
- Matte Photo Paper MP-101
Performing Borderless Printing on any other type of paper may substantially reduce printing quality and/or result in printouts with altered color hues.
Borderless Printing on plain paper may result in printouts with reduced quality. Use them only for test printing. You can perform Borderless Printing on plain paper only when printing from your computer.
bullet_s.gif Depending on the type of paper, Borderless Printing may reduce the print quality at the top and bottom edges of the paper or cause these parts to become smudged.
See A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide.
See Letter, Legal.
See Envelopes.
sikaku.gif A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide
Size
Printable Area (width x height)
A5*
5.56 x 7.95 inches / 141.2 x 202.0 mm
A4
8.00 x 11.38 inches / 203.2 x 289.0 mm
B5*
6.90 x 9.80 inches / 175.2 x 249.0 mm
4" x 6" / 10 x 15 cm
3.73 x 5.69 inches / 94.8 x 144.4 mm
4" x 8" / 10 x 20 cm*
3.73 x 7.69 inches / 94.8 x 195.2 mm
5" x 7" / 13 x 18 cm*
4.73 x 6.69 inches / 120.2 x 169.8 mm
8" x 10" / 20 x 25 cm*
7.73 x 9.69 inches / 196.4 x 246.0 mm
Wide*
3.73 x 6.80 inches / 94.8 x 172.6 mm
* This page size can be used only when printing from your computer.
o_ap_069.jpg o_darkblue6.jpgRecommended printing area
o_lightblue7.jpgPrintable area
sikaku.gif Letter, Legal
Size
Letter
8.00 x 10.69 inches / 203.2 x 271.4 mm
Legal*
8.00 x 13.69 inches / 203.2 x 347.6 mm
o_ap_074.jpg o_darkblue4.jpgRecommended printing area
o_lightblue5.jpgPrintable area
sikaku.gif Envelopes
Size
European DL*
4.06 x 7.12 inches / 103.2 x 180.8 mm
US Comm. Env. #10*
3.86 x 7.96 inches / 98.0 x 202.1 mm
* Envelopes can be used only when printing from your computer.
o_darkblue8.jpgRecommended printing area
Jun 30, 2011 | Canon PIXMA MP240 All-In-One InkJet...
How to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Dec 20, 2010 | Brother IntelliFAX 3800 Plain Paper Laser...
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
I would like to feed and print an 6" x 9" envelope
Print 4" x 6" photo images in normal mode in about 60 seconds; up to 17 ppm ... 3/4 Envelope. 9 Envelope. A4. A5. B5 Envelope. C5 Envelope. DL Envelope. 6 3/4 ...lexmark.com/lexmark/product/home/15/...?tabId=1
Dec 04, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper Type and weigth Fot Lexmark C912
Media paper weight: is 20lb or 75gsm.
Media type: card stock, envelopes, Glossy paper, Paper Labels, Plain Paper, Transparent.
Media size: A3, A4, A5, Banner up to 11.69"x36", Executive, JIS-B4, JIS-B5, Ledger, Letter, legal, Super Tabloid, B5, C4, C5 DL, 7 3/4 9, 10 Envelopes.
demension is in inches, you need to convert it to centermeter.
Oct 30, 2008 | Lexmark C912 Led Printer
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
Max Paper Weight
Here ya go...
Tray 1: (standard) 16 lb. Bond – 80 lb. Cover (60 – 220 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, business cards, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards, Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, A5, A6, B5 JIS, B5 ISO, 3 5 in. Index Cards, custom sizes; Envelopes: #10 Commercial, DL, C5, #5 , #6 , Monarch, Booklet, Lee (A7), Choukei 3 Gou, Choukei 4 Gou, custom.
Tray 2: 525-sheet tray (standard) 16 lb. Bond – 28 lb. Cover (60 –122 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards,Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, B5 JIS, B5 ISO; Envelopes: #10 Commercial, DL, and C5.
Tray 3: 525-sheet Feeder (standard on DX) Same media weights and sizes as Tray 2.
Tray 4: 525-sheet Feeder (optional) Same media weights and sizes as Tray 2.
Nov 12, 2007 | Xerox Phaser 8400 Laser Printer
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus 880 InkJet Color Printer Logo
249 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
