Question about Acer Aspire 3000 Notebook
I have just run the recovery discs on acer aspire 3000 but when it goes to the 'welcome to microsoft windows' page... computer freezes and I can't click 'next' to set up the computer.
  • 1 more comment
  • Annette Temple Jan 09, 2009
    Bet you your battery is ****.... I have found another link on this site that says to remove your battery and it works!!!
    Don't know why - but disable your battery and you will be able to go through the set up.
    Try to find the link - it was to do with keyboard and mouse freezing and you can disable the battery permanently in your device manager... but in the meantime - just take out the battery and plug in the laptop!
  • jpscolon Jan 14, 2009
    I bet is the memory i had a similar problem with this computer and I changed the memorry , now it is running good.
  • lopesclan Jan 25, 2009
    Thank you soooooo much I have tried everything else and no solution! Thank you it worked like a charm! xoxoxoxox. My keyboard wouldn't work either nor the mouse or the internet. it was driving me crazy until I found this site.
I have an Acer Aspire 5733z-4851.....when I turn it on it starts up then goes to a screen saying "SETUP IS STARTING SERVICES"....after a few moments an "INSTALL WINDOWS" box pops up. The box says" WINDOWS...
Factory reset on acer aspire 5733z-4851 without reset disc. ALT+F10 keys at boot will start Acer recovery process. if this keys combo doesn't work, enter BIOS pressing F2 at boot and check if D2D is disabled, enable it then press F10, save and exit.
The following might later prove of value:
Product support
Then there is a process of booting from a USB stick. But you need an iso file of Windows 7. Microsoft Recovery Center likes retail versions with keys but not OEM versions.
Just something you might need to take a look at.
Aug 11, 2017 | Computers & Internet
Acer aspire one zg5 no erecovery
Hi ultraview27...
How to reinstall the Operating system on your computer
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
1.Restart the computer.
2.When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
3.If you are prompted with a Microsoft Windows boot screen, press the Enter key.
4.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive,you will have to have an external optical disc drive because it will be used in order to recover the Operating System using Acer Recovery Media.
2.When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
3.Press the CD-ROM drive eject button and insert the disc labeled System CD.
4.Close the CD-ROM tray.
5.Refer to on screen instructions to select either CDROM or USB CDROM.
6.The computer will boot from the Acer Recovery Media
7.When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
8.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Please take time to rate me
Sep 27, 2011 | Acer Aspire One PC Notebook
How do i reset my accer aspire 5336 laptop to factorydettings
This information can be found on the support page of Acer.com
http://acer.custhelp.com/app/answers/detail/a_id/2631
How do I reinstall the Operating System on my computer?
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Thanks for using FixYa.com
Apr 28, 2011 | Acer Computers & Internet
My Acer Aspire 3000 can not log on window, because forget the password?
The windows has to be reinstalled ( Formatting the Hard Disk ) Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer.
  1. Restart the netbook.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
  5. Select ' completely restore to factory defaults '
Oct 21, 2010 | Acer Aspire 3000 Notebook
After installing an automatic update, upon re-starting, my computer will load the windows xp welcome screen, the blue bar, under the windows xp icon, scrolls as if the computer is booting up. The screen...
Sounds like the HAL.DLL problem that I have with my Aspire One.
Try booting off a genuine Windows XP disc and choosing the 'recovery console' option. At the command line, type 'CHKDSK C:' and press Enter. If you're lucky, that will do the trick.
Feb 07, 2010 | Acer Aspire 5050-3242 Notebook
Boot sector
go 2 bios set up make your cd rom b the first bottable device.
Jan 28, 2009 | Acer Aspire 3000 Notebook
Computer freezes on start-up
whenever your doing a cd recovery you need to remove the battery
use ac power
if its still freezing up you'll have to run windows again
Windows uses a lot of power to install
Jan 09, 2009 | Acer Aspire 3000 Notebook
Acer aspire 3000
Could be a bad memory chip or a hard drive crash. Can you hear the hard drive engage? If so, is there any clicking or dull thunking sounds? Both of these are indicators of a hard drive failure.
Jun 21, 2008 | Acer Aspire 3000 Notebook
My acer aspire 3000 is too slow
Well, there are too many many reasons that can cause an Acer notebook running slow or freeze now and then, for most cases, it can be affected by various hidden Windows errors. Those problems firstly cause your Acer slow, and then freeze up occasionally. One day crash all of a sudden. If you prefer a quick solution to detect and fix all the problems, try the easy solution here: http://www.speedupacer.com/
Jan 22, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
