Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Monitor goes into Sleep Mode immediatly upon turning on computer
I know I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
  • Anonymous Mar 31, 2009
    im trying to get into my computer put the screen keeps saying monitors going to sleep
  • Anonymous Apr 18, 2009
    monitor stay in sleep mode no input signal Hp vs17e monitor
I have a LCD panel it is connect to to the LCD. I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
Posted on Jan 22, 2009
    Scholar:
  • 58 Answers
It depends.
I will not talk about the setting on the computer because you know.
If your computer goes to sleeping mode you have to press the power button once and short.
If your monitor goes to sleeping mode and your computer is on you can press a mouse button and a key like the ESCAPE key.
What is usually do is first.
press a mouse button, then the escape key then turn of monitor and turn on. Whit each step i wait until is see a screen. If this all is not working i think you have a problem with the resolution you have set in windows. In this case you have to reboot your computer to safe mode, change your display to a low resolution, reboot and in windows you can change your setting again. Always test your setting before you apply.
good luck
Posted on Jan 09, 2009
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
My monitor goes in sleep mode after few seconds. how to swich off sleep mode on monitor?
Just go to Power Option of your computer under the >CONTROL PANEL
> click the power option and you will see the
>balanced
click change plan settings
>turn off the display to "NEVER"
and
> Put the computer to Sleep to "NEVER"
hope it helps...
Sep 08, 2010 | Computers & Internet
Monitor going to sleep upon Bootup.
Open your cpu cabinet.
refix your RAM memory .
Pull cmos cell for 10 minutes so all settigns are defaults.
Also remove PCI cards from PCI slot .
Then check.
Let me know if you need more assistanse.
thanks.
Aug 31, 2009 | HP w1907 LCD Monitor
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
May 24, 2009 | Dell Dimension 3000 PC Desktop
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
you can change this by going to control panel then display icon and changing it in settings.
Sep 07, 2008 | Computers & Internet
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
Mar 19, 2008 | Computers & Internet
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
3,849 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
