Xerox Workcentre 7655 - Printer thinks it's out of paper
I try to print a booklet but the machine status says the job is ''held: resources required''. The reason is it thinks it's out of paper but the tray is full. How do I resolve this problem?
4 Suggested Answers
  • 31 Answers
SOURCE: Printer thinks it's out of paper
Have you tried pressing the start button after you loaded the paper?
Also, try restarting the printer while keeping the paper in there.
Posted on Jan 09, 2009
  • 2246 Answers
SOURCE: "Close the Tray 5 Top Cover" warning cannot be
see this page for instruction to solve
Posted on Jan 22, 2011
  • 922 Answers
SOURCE: Close the Tray Top Cover
This can happen if the finisher is not secured. Make sure that all of the levers that hold it in place are locked in place. Good luck!
Posted on Jan 24, 2011
WHAT IS 007-243 code error
This fault code isn't specific to one location/function on your machine, however, I believe it is directly related to your paper trays. Other fault codes begining with 007-??? state a tray sensor error, misfed media in a tray etc...
If you're trying to print to a specific tray and it won't print giving this error, you may want to try printing using a different tray. It is entirely possible you have some jammed up paper in the paper path and this will stop all trays from printing.
Potential solution:
Ensure you don't have any paper jams related to your paper path and trays, herre is a link that provides you all iinstructions to clear any paper jam on your device
NOTE: The above link is a support knowledgebase and you can search on any problem you may have with your product by typing the natural language query in the search field, paper jam, can't print, scan fails transferiing etc...
Once you have determined there isn't a paper jam or if so gently remove any misfed paper.Reboot the device PO/PO power off/power on.
If the print jobs fail again, check your job status and see if there is any info listed for your print job, could be a media mismatch.
Try printing to another paper tray, if your job is calling for paper from tray 3 try using tray 4 or tray 5 etc..
I have provided a generic response to this question and kind of throwing ideas out there, if you could provide additional information I may be able to give a better solution.
Check the details of your job in the job status list?
A lot of times the machine will provide good direction on potential issues with a print job.
Are you trying to print on a custom paper size?
If you tell the print driver to print to tray 3 and you have 8.5X11 loaded in tray 3 and your print job from ypour PC is actually 8.5X14 then the job will not print simply put the media has to match the job.
I hope this helps.
Mar 10, 2015 | Xerox Workcentre 7345 Printer, Copier,...
Xerox WC 7655 host to host usb failure. comunnication error 7655
Try changin the usb connector of the cable that goes from the screen to the rear left of the machine. There are 4 connectors there.
Oct 01, 2014 | Xerox WorkCentre 7665 Copier
Xerox 7655 can it borderless print
No it's fisically not possible. There will always be an edge.
Try to print on a bigger piece of paper and cut it.
Apr 04, 2013 | Xerox WorkCentre 7665 Copier
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
Paper size Mismatch on Xerox workcentre 4118 i cant print
Most likely the tray setting has changed, Here is what to check.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until the required tray is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until the required paper size is displayed, and then press the [Enter] button.
  5. Press the [Stop] button to return to the Standby mode
I am sure you will find one of the tray settings to be incorrect.
If not, click on the printers on your computer, Right click the 4118 and look in the printer properties. One of those settings may be off.
More likely is that the machine settings have changed for whatever reason.
Jul 07, 2010 | Xerox WorkCentre 4118 Network Kit...
Command sent to printer but printer is not printing the document
First of all make sure your network cable is connected properly and has not come loose.
Most likely though is that the IP address has changed .
Do you know your printers IP address? Have an old copy of the configuration to compare it to a new one?
That machine is notorious for changing the IP address and I really suspect that is the problem.
You can try turning it off and back on.
You can check the job status queue and be sure the machine is not holding a job . It could be " held for resources." What that means is a job was sent to the printer and the print driver and settings on the printer are different. I will not print if those settings are different.
By that I mean, on the print driver, it sends a job for 8 1/2 x 11 plain paper. The machine settings say it has 8 1/2 x 11 bond paper or visa versa. If the settings between your computer and printer are different it will hold the job until they match. Look on your printer screen and be sure the tray settings are correct.
Jan 07, 2010 | Xerox Phaser 8560DN Laser Printer
Jan 09, 2009 | Office Equipment & Supplies
1,125 people viewed this question
