Question about Insignia Digital-to-Analog Converter for Analog TVs
Insignia digital tv converter/indoor antenna no signal
I just bought 2 Insignia MS-DXA1-APT converters for 2 different portable sets. Also bought RCA HDTV indoor VHF/UHF/FM antenna. Get fair reception without converters. 70's B/W RCA works in analog with converter off - but converter can find no channels. Other TV - 5 year old RCA works fine on antenna, but nothing with converter installed - used same converter for test - and antenna in window.
  • 5 more comments
  • modeltford Jan 11, 2009
    The older set needed the rabbit ears anyway - has a built in antenna which won't connect to converter. At least I don't need 2!!
    NOW I'm getting results with converters off - weird tho, I switched boxes and now I get picture a bit better that previously on both TVs. I DO still get the same results on both with converter on - get no signal on either set.
    I'm located approx 40 miles north of Seattle - reception with rabbit ears alone is fair most of the time, sometimes better, sometimes worse - but never great.
    Thanks for the ideas!
    Sorry - should have been clearer. I turned the boxes on and ran auto-detect, and still showing no signal. I understood that there was already network stations broadcasting in Digital - could they have the signal that low that I couldn't receive them at this time?
  • modeltford Jan 12, 2009
    Just looked at the 4 locals sites - all say about the same thing, none say that they are transmitting now in HDTV! Since the boxes work ok for now, guess I'll just have to wait & see!
    Thanks for your help, DickCanFixIt!
    Rich
  • charh20 Feb 22, 2009
    I had the same problem but realized that when it said NO SIGNAL,,,that just means NOOSIGNAL for that station,,,,,,,change the channels and you will see that you do have a conection,,,,,,,,
    Good Luck
  • modeltford Feb 22, 2009
    Used auto-detect when first hooking it up - no signal on ANY station
  • johnsonclan6 Feb 28, 2009
    converter box signal received throughout house, except in basement.
  • Anonymous Apr 20, 2009
    I have this same problem ... no signal. Damn congress!
I bought a new HDTV and now i get no channels. Before i was getting 5 channels with analogue now nothing. Thanks a lot Mass Media cable Monopolies. I cant afford cable and will miss my local channels. I only have rabbit ears, can not put up roof antenna, so what can i do? thanks damn Digital
Posted on Jun 13, 2009
    President:
  • 948 Answers
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Posted on Jan 10, 2009
  • 1 more comment
  • Dick
    Dick Jan 11, 2009
    When you say "same results on both with converter on - get no signal on either set," do you mean you have the boxes on and have gone through the auto-detect routine while the antenna is connected and the software in the box is telling you that it searched but found no channels?
    Or do you just have the box turned on and are flipping the tv channels? You must let the box search for the digital channels, then change the channel with the converter box. Your TV should be on channel 3 or 4. It is very unlikely you are out of range of all digital channels being only 40 miles from a major metropolis.
  • Dick
    Dick Jan 11, 2009
    "could they have the signal that low that I couldn't receive them at this time?"
    That is possible. Try browsing to your local television station's website and see if they have any information up about their current status. Is this on near you?http://www.kirotv.com/station/1874986/de...
  • Dick
    Dick Feb 23, 2009
    The date for the mandatory change has been pushed back to June '09. Many stations have switched anyway, but not all of them.
I had the same problem but realized that when it said NO SIGNAL,,,,it just ment for that station,,,,,switch channels and they will start to come in,,,
Good Luck,
charh20
Posted on Feb 22, 2009
I need to program a universal remote, a ge modal249 my Insignia modal NS-DXA1-APT digital analog converter chgang4895@yahoo.com
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control our converter.
Apr 19, 2010 | Insignia Digital-to-Analog Converter for...
Where can i find the method and codes to program my insignia digital converter remote for my symphonic tv
http://insigniaproducts.com/cms/documents/NS-DXA1-APT%20UM%20EN.pdf
Here are the Symphonic TV codes. These are for a universal remote OK
SYMPHONIC
520 904 906
Hope this helps. As for the insignia, if you can not click the link copy and paste. What you need is on page 18, instruction on how to program your converter. Download if you lost it and print if needed. You will need Acrobat to view this. Good luck
Sep 12, 2009 | Insignia Digital-to-Analog Converter for...
Have an Insignia (NS-DXA1-APT). Have tried 3
connect up another tv and see if it is the tv or where you live.if the tv is the culprit then you have a defective tuner in the tv and is probably is not available.
Jul 18, 2009 | Televison & Video
Programming Insignia Digital Box to Phillips Universal Remote
I have the Phillips Universal Remote (model#SRU4208WM) and I have the Insignia digital converter box (model#NS-DXA1-APT). The code was 0267. The Insignia converter box is the one the government grants work for.
Feb 03, 2009 | Insignia Digital-to-Analog Converter for...
Insignia NS-DXA1 APT remote control doesn't work
Set your TV input to match the input your have your Insigna connected to. Then run the Insignia setup. You are getting a distorted screen because you probably have the Insignia connected to channel 3 and the TV on channel 4.
Dec 30, 2008 | Insignia Digital-to-Analog Converter for...
Insignia digital converter box NS-DXA1 saying no signal
Connect your Insigna unit to your television video 1 input. Connect your antenna to the Insigna. Turn on the television to video 1 source. Power on the Insignia. Now go through the auto-detect routine to set up your television stations.
Dec 29, 2008 | Insignia Digital-to-Analog Converter for...
Remote doesn't work for the Insignia converter box
Strange as it seems, both converters had "bad" batteries included for the remote. Bought new batteries, problem solved.
Dec 27, 2008 | Insignia Digital-to-Analog Converter for...
Lost the Welcome/Installation Menu
http://www.ezdigitaltv.com/support-files/ns_dxa1_manual.pdf
All you have to do is use the auto tuning function. Your remote control has a menu button, you can get to the feature via the on-screen menu.
If you press the menu button while the box is on and you see no menu, change your television's input to match what the box's output is.
Nov 23, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
3,160 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
