Question about HP LaserJet 1300 Printer
HP 1300 randomly printing pages with tiny smiley faces and square
My HP 1300 will randomly pull a piece of paper through and print a smiley face or a small square in the top left-hand corner of the paper. It does it when I log onto my computer and every few minutes. It seems like the problem started when another printer was added to my computer.
  • 33 Answers
Try reinstalling your drivers. The computer may be confused with two different sets because of your second printer. If that doesn't work, and you have another computer available, hook the printer up to that one and install the drivers and see if the problem persists. If it does, then I really don't know what you can do, because that means the problem is in the printer's internal control and would be very hard to fix. If it doesn't persist on the second computer, then you know it's the first computer that's causing it. If nothing else works, try running a scan for viruses and spyware because they too could be interfering with your printer drivers. The computer actually does communicate with the printer even when you're not printing anything. It basically checks to make sure it's still there and waits for a response back with the printer status, etc. Some other program (whether wanted or unwanted) could be interfering.
Posted on Jan 09, 2009
Separator Sheets with smiley faces
Attempt to restore printer to factory defaults to cure this issue.
Sep 06, 2017 | Lexmark T644 Laser Printer
Should print paper face up or down on hp office jet 7310?
Load the originals face-up in the ADF with the short edge of the page to the left.
Jun 17, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Hello, I have problem with Printer Kyocera FS-1300.. when i connect it to pc, it starts to print some symbols, like smiley face on left corner of page, and i cant stop it, when i disconnnect my device...
Hi. I would suggest that you unplug the printer, reinstall software and check you computer for viruses. If i continues, try letting it print out. maybe someone set so that 30 pages with a smiley would be printed next time you plugged it in. I how this will fix you problem.
Jun 08, 2011 | Kyocera Fs-1300d Printer
This HP C6180 printer will do fine for awhile, then it will quit printing and will give a message of "place paper face down in tray". It is white paper and there is no face down. Please help.l Patra...
Believe it or not, some paper manufacturers have subtle differences in the way that the paper is cut (even for plain white computer paper), so that there is an up-side and a down-side, so it affects the "feeding" action of slipping the next piece of paper into the printing path.
This could be important for special paper types, but a real drag if you're printing text.
Try another batch or vendor of paper.
Mar 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
ADF Pulls paper but prints a blank page
The wire ends have different sizes to avoid to connecting it to the wrong port. It will only fit to the right one.
If the copy prints a blank page, try copying again with the document facing up on the ADF.
Hope this helps!
Mar 03, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Will not "Print" copies.
It may be that you are putting the page face down in the paper feeder when it needs to be face up or the other way around.
Jan 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printing
Dear jamin4volks;
As per this excerpt from the Oki B4350 User manual:
"FACE UP AND FACE DOWN PRINTING
For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
Hope this helps;
Frank
Apr 18, 2008 | OKI B4350 Laser Printer
I have installed the HP Photosmart C7280 All-in-One and tried to print an article off the computer. I have paper loaded in the tray-I get a message Out of Paper. Load paper face down in Main Tray. What's...
I experienced the same problem on a HP Photosmart C7280 All-in-one printer. The problem was that the light-blue plastic piece, which covers half of the printing paper tray, had gotten out of alignment with the gray piece which covers the other half of the paper stack. Pull the blue plastic tray out and align it properly.
Apr 11, 2008 | Office Equipment & Supplies
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
      5. Press Copies .
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
HP LaserJet 1300 Printer Logo
702 people viewed this question
Seeker5211
Seeker5211
